LWAP to Autonomous
Answered Question
Nov 19th, 2012
I have a new CAP-3500 series access point and i need to convert it to autonomous since my controller has not yet arrived.
i know for the fact that it can be done on 1200 and 1100 series AP but i am not sure if it is still possible with newer model APs.
I cannot find a document saying that it is also working for these new AP models.
Please help. Thanks!
Correct Answer by Leo Laohoo about 4 years 2 months ago
I have successfuly converted it to the 15.2 version, at first i tried the earlier version of the Autonomous IOS but it was looking for "k9w7" which only 15.2 version has, so i was not successful in converting to lower version.
You can't run autonomous IOS version 12.X for the 3500.
But as the note said that 15.2 version is site survey mode only. what will be the impact of this for the production?
I was able to configure basic single SSID with WPA2-PSK. but what are the limitations for the "site-survey only mode"? will it support raidus authentication and multiple SSID broadcast?
It wasn't meant to go into wifi production, take note of that.   You're probably the first I've read who wants to run autonomous IOS as a service.  I'd strongly recommend you wait for your WLC.
Correct Answer by Leo Laohoo about 4 years 3 months ago
Site-Survey Only Mode for 3600, 3500, and 1550 Access Points
You can install Cisco IOS Release 15.2(2)JA on Cisco Aironet 3600 and 3500 Series access points and on 1550 series outdoor access points to perform site surveys. This release runs on these access points with limited functionality. You can manually adjust these settings on the site-survey access points:
Channel on each radio
Transmit power on each radio
Enable and disable the radios
Manually set basic and supported transmit rates
Enable advertised cell power in beacons to client to enable DTPC for doing active surveys
Enable and disable SSID broadcast in beacons
Enable open authentication
If you have a valid Service Contract then you can download the IOS from here.
Overall Rating: 5 (2 ratings)
mjohnson1914 Mon, 11/19/2012 - 05:26
There is iOS code for this AP ... You have to download it from Cisco with your cco account.
Correct Answer
Leo Laohoo Mon, 11/19/2012 - 14:03
ejlbarcelon Mon, 11/19/2012 - 16:22
does this means that for 3500 series that it will only run on site-survey mode and will not have full autonomous capability?
Leo Laohoo Mon, 11/19/2012 - 16:51
You can run a 3500/3600 to provide wi-fi service but CleanAir is disabled.
George Stefanick Mon, 11/19/2012 - 18:59
Leo -- Correct me if I am wrong .. But Cisco is not recommending autonmous mode for these APs in production. Only site survey .. ??
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Leo Laohoo Mon, 11/19/2012 - 19:07
You're right, George.  Autonomous wifi service not "recommended" but it works.
The OP did say that his controller has "not yet arrived", hence my response.
ejlbarcelon Wed, 12/05/2012 - 00:16
Hi Leo,
Also can i downgrade it to 12.4 version?
Correct Answer
Leo Laohoo Wed, 12/05/2012 - 00:21
ejlbarcelon Wed, 12/05/2012 - 00:28
the problem is the finance is holding up the business's budget, i was just trying to help out since they badly need the wifi service and the budget release is still on approval. and no one knows when it will be approved.
Leo Laohoo Wed, 12/05/2012 - 00:38
I haven't tried this but I do not believe RADIUS stuff will be supported.
Leo Laohoo Sat, 12/08/2012 - 20:24
A little birdie told me the 15.X autonomous IOS (aIOS) for the 3500, 1600/2600/3600 is a FULL IOS with Spectrum Expert.  So yes, you can do RADIUS.
Apparently, the GUI is alot better.  Give this a try!
ejlbarcelon Sun, 12/09/2012 - 18:36
wow that will be great. this will be very useful for us. Kindly give my thanks to the little Birdie too
Leo Laohoo Mon, 12/10/2012 - 18:58
Be careful if you are doing 802.1q as I believe there is a potential bug.  I'm trying to raise a TAC Case.  Will let y'all know.
ejlbarcelon Mon, 12/10/2012 - 19:02
what exactly part of the 802.1q you seem to found as a potential bug? as for now we are using single VLAN for the AP.
Leo Laohoo Mon, 12/10/2012 - 19:30
Well, I've upgraded a few of our 1140 from 12.4(25d)JA to 15.2(2)JA.  As soon as the WAP boots up, you can't remote into it.  You can see the details in CDP just fine.
The only way back into the WAP is to change the switch port's Native VLAN value to the value of the management VLAN.
Downgraded the IOS and it works just fine.
Leo Laohoo Mon, 12/31/2012 - 15:07
Cisco re-released an updated code and ends with JB.  This should fix the problem.
Related Content
