C20 Microphone extension cable Max lenght
Good day
I would like to know if it will be possible to extend the standard C20 microphone cable past 15m...
Thanks!
Hey Martin
We can use extension for mics for C20. Its even listed in parts and components guide:
CTS-QSC20-MIC=
Performance Mic 20 - 7.5m cable attached
CAB-MIC20-EXT=
Extension Cable 10m, for CTS-QSC20-MIC, 3.5mm F to 3.5mm M
So we can safely say that you can use microphone with 2 extension = 37,5 meters, just over 90 ft.
Rafal
Rafal Szeremeta
Hello Chris
Microphone cable for C series systems can be extent up to 100ft.
Rafal
Hi Rafal!
If I remember it correct the last official statement for the C20/SX20 I heard was:
* no other mics then the original square ones
* no extensions (SX20 also regards the camera)
Hey Martin
CTS-QSC20-MIC=
CAB-MIC20-EXT=
Rafal
Hi there
Thank you very much for the information rszereme!
