XR OS and Platforms
Hi, All.I want to integrate IOS router to oxidized. I tried to login with pub key, but IOS asks password. Status, Current ConfigurationVersion RP/0/RP0/CPU0:RTR# sh ver Cisco IOS XR Software, Version 7.9.2 Copyright (c) 2013-2023 by Cisco Systems, In...
  PID : N540-24Z8Q2C-M IOS-XR : 7.8.2 I want to know about smart licenses. The command is enable, but when I apply the command below, it behaves as if the license is off. RP/0/RP0/CPU0:PE-02#show run | inc licWed Mar 27 10:13:34.359 KSTBuilding confi...
Hello,I have NCS5501 that I get the PCIE Uncorrectable Fatal Error/Surprise Link Down Error on Tomahawk LC.   I am trying to look it up to gain a better understanding of what this is.    Anyone ever seen this before?   Can you clarify what it is refe...
dddwood by Level 1
  • 171 Views
  • 7 replies
This is a fixed port router with a mix of SFP+, SFP28, QSFP28 and QSFP-DD ports The install guide says they are split between slice 0 and slice 1 with 24 ports per slice How does this translate into the rack/slot/instance/port schema ?  is the slice ...
Team,,We need to do below similar configuration of ASR1002 in our new ASR9001 please supportip dhcp pool PDY-3network 30.23.0.0 255.255.0.0default-router 30.23.2.1dns-server 8.8.8.8 4.2.2.2bba-group pppoe PDY-3virtual-template 3sessions per-mac limit...
