UC500 MultiSite Manager
Answered Question
Nov 20th, 2012
Hello All,
This may be a silly question, but what exactly does the 'Multi-Site Manager' do in a UC500?  If I'm setting this up remotely, is there a good chance that I'm going to lose my connection for some reason (I'm using one of the UCs for a VPN connection).  Can anyone point me to a document somewhere that can highlight exactly what it is that the MultiSite Manager adds / changes / installs?
Thank you,
~Shawn
Correct Answer by janickle about 4 years 8 months ago
Hi Shawn,
Multisite manager is used to configure a VPN that allows calls between 2 or more UC’s.  New additions to CCA allow the multisite manager to also create just a data VPN without the dial plans to another router.
The multisite manger will configure the crypto maps and ACL’s on the UC.  So if you are doing this remotely through a VPN there is always a chance that you will lose your connection.  If you need additional information on the Multisite manger please let me know.
Thank you,
Jason Nickle
Overall Rating: 5 (1 ratings)
Correct Answer
janickle Sun, 11/25/2012 - 03:40
  • Bronze, 100 points or more
Hi Shawn,
Thank you,
Jason Nickle
