Cisco 2921 Router with the ip http access class command
saroj pradhan
the cisco 2921 Router has a default  ip hhtp  access class command  found  in it. Just  i  changed the default  IP to the new ip  i will use.
The Router is accessable  from the LAN only  but  not from the internet  configured the Public ip . I think this is due to the standard access list 23 .
Please advice  how will i access the Router from the Internet using the Public IP.
Saroj Pradhan
9 Replies 9
johnlloyd_13
Level 9
Level 9
hi saroj,
please post your 'show run' output.
Rahul Kukreja
The ACL used with the following command is used to restrict the GUI Access to router (like CCP)
Also this ACL is the standard ACL, so will only match the source ip address not the destination.
ip http access-class 23
http://www.cisco.com/en/US/docs/ios/12_1/configfun/command/reference/frd1005.html#wp1020068
Check if the same ACL is applied in the vty lines -
line vty 0 4
access-class 23 in
Remove this command and check or put "permit any" at the end of ACL and check.
- HTH
  Rahul
As  i am unable  to access the Router from the internet due the ip http  access class command  need help to remove the command  from the routeer. please advice.
Saroj
Please attach your running confugration and let us via what means you are accessing the Router from Internet and the ip address of router (example - telnet, ssh, CCP etc)
ip http access-class is used to restrict the GUI access access of the router and if you just want to go ahead and remove this without any further troubleshooting, here is the command -
Router#conf t
Router(config)#no ip http access-class 23
- HTH
Rahul
You don't have line vty access with ssh/telnet ?
Regards.
Alain
hello,
Just a tip here, if you are going to be making changes on a remote router that you are not sure will result in disconnecting your session, save the config and use the reload command to reboot the device if the session disconnects:
(config)# reload in
Joel
_______________________________
Please rate helpful posts and answered questions!
Joel _______________________________ Please rate helpful posts and answered questions!
if you are using internet, the first thing you must do is to ping the router
your router must have  default route to the internet
@joelgooding
good tip....!!
Ricardo Ochoa
Hello, please post the next commands:
sh run int "WAN Interface"
sh access-list
sh ip route
sh running-config | section line vty
