Set Username & Password on Cisco 3750 Switch
Nov 25th, 2012
Hi Team,
I want to configure " Username & Password" on Cisco 3750 switch.
I need to configure as "username xxxxxx  privilege 15 password 5 xxxxxxx "
Is it possible to create password with level 5 ?......
I want to know about level 5 "password" & level 7 "password" ?
when i tried I am not able to configure with " password 5"
Please help me resolve the issue?.
Sen
Overall Rating: 4.6 (6 ratings)
Mark Potter Sun, 11/25/2012 - 18:28
Try:
username privilege 15 secret
e.g. name = mark , password = mypass
username mark privilege 15 secret mypass
Basically password is easily reversable, secret isn't.
balakrishnansenthil Sun, 11/25/2012 - 19:10
Thanks Potterm,
But i want use "Username privilege 15 password 5 $1$Z3fsOO.p$7alNAnUmVSd5ucARj7CsO0"
is it possible?...
regards,
Sen
Reza Sharifi Sun, 11/25/2012 - 19:14
  • Cisco Designated VIP,
    2017 LAN
The options are 0 or 7.  There is no 5.
see below from a 3750
Switch(config)#username cisco privilege 15 password 5
% Incomplete command.
Switch(config)#username cisco privilege 15 password ?
  0     Specifies an UNENCRYPTED password will follow
  7     Specifies a HIDDEN password will follow
  LINE  The UNENCRYPTED (cleartext) user password
Mark Potter Sun, 11/25/2012 - 19:17
You can't use password with 5.
password only supports 0 and 7
secret supports 0 and 5
SWITCH1(config)#username mark privilege 15 password ?
SWITCH1(config)#username mark privilege 15 secret ?
  0     Specifies an UNENCRYPTED secret will follow
  5     Specifies a HIDDEN secret will follow
  LINE  The UNENCRYPTED (cleartext) user secret
If you want 5 you need to use secret as in example below.
username privilege 15 secret 5
Best of luck.
Mark.
balakrishnansenthil Sun, 11/25/2012 - 19:32
Thanks Potterm,
I try this.....
What is difference of this below two method ? What is the enable password for this?...
Sen
Mark Potter Sun, 11/25/2012 - 19:37
secret I believe uses better password security/algorithm to store passwords in the conifg.
password is less secure, better off googling that.
The enable password is whatever you make it.
enable secret
e.g. enable password = mypass
enable secret mypass
Mark.
balakrishnansenthil Mon, 11/26/2012 - 00:11
Please find the below config.( This one already configured inside the switch)
Config:
enable secret 5 $1$UK0G$d4QXwakilHzVNyjZEjyXk.
username privilege 15 password 7 122050460A5809537D2808
aaa new-model
I wan to configure like this is?....
Here already some one configured secret 5 < password > , Can create one more secret password.
Please i want to use encrypted password is it possible?....
Error:
ERROR: The secret you entered is not a valid encrypted secret.
To enter an UNENCRYPTED secret, do not specify type 5 encryption.
When you properly enter an UNENCRYPTED secret, it will be encrypted.
Thanks.......
Reagrds,
Sen
packettracer86 Mon, 11/26/2012 - 02:01
just do it like mentioned above.
For unencrypted password:
username superman privilege 15 password mypassword
Result in config:
username superman privilege 15 password 0 mypassword
U can also set the "service password-encryption" globaly
then the config will look like this:
username superman privilege 15 password 09878419047
But that is just some kind of Hash afaik! So you can easy "encrypt" it, google for that ..
More Secure is:
username superman privilege 15 secret mypassword
Looks in config:
username superman privilege 15 secret 5 $1$hqMA$adgOgpNk91XnQPjwv6CgT.
This is more secure ..
So you have two choices,
username XY priv 15 password XY
username XY priv 15 secret XY
and optionally (i would always set this, it encrypt all PW's in the cfg)
Greets
John Blakley Mon, 11/26/2012 - 04:09
  • Purple, 4500 points or more
To change your password, do everything everyone else stated above. The difference between the passwords are:
The "password" attribute allows type 0 (unencrypted) and type 7 (vigenere). The type 7 is easily decrytable and there are several utilities online that can reverse the password with ease.
The "secret" attribute allows type 0 (unecrypted) and type 5 (MD5) hash. The type 5 is a one-way hash that the router can compare your password to when logging in. If your password hash matches the local password, you're allowed in.
The reason that you have the choice of type 5 or type 7 "secret 5" or "password 7" is because when you have a running config, you can copy and paste the already "hashed" version of the password and the system knows how to deal with the password that you just pasted. In fact, if you were to put "usernam admin password 0 admin", IOS will change it to "username admin password 7 xxxxxx" if the "service password-encryption" is enabled. The "service password-encryption" doesn't need to be enabled for the "secret" attribute, but there are other passwords in the router that are only affected if the password encryption is on, so I still recommend having it enabled.
In short, if you don't know what the password hash is because you don't already have a running config in hand, then always use "0" as your password attribute and the system will change the attribute to either 7 or 5 depending on your use of "password" or "secret" respectively.
HTH,
John
***** Please rate all useful posts *****
balakrishnansenthil Fri, 12/07/2012 - 01:03
If i create local account like " username xxxxxx privilege 15 password 7 023E077B07041D791C"
When i can use this local account? after configured i try to login but am not able to to login....
i thing if not tacacs then only i can login am i correct?......
Please make sure how to use this account? when i can login?...
Sen
John Blakley Fri, 12/07/2012 - 03:56
If you have tacacs or radius configured with aaa authentication, it's going to use one of those servers first. If the server responds at all, it won't fail over to the local database. If you're not using aaa authentication, and you only need to use the local database, you'll need to change your lines to use the local database:
line vty 0 4
login local
Then you'll be able to use the login. Since you mentioned tacacs though, you could do something like:
aaa authentication login default local group tacacs
If the user doesn't exist on the local database, it should roll over to the tacacs server.
HTH,
John
Related Content
