Local HDD through Clientless VPN
kedrbankcom
Hello. How to connect local HDD through Clientless VPN???
ovidio.catrina
ssl vpn with rdp i think
Yes, you can use an SSL VPN to access RDP to specific systems/servers.
Joel
_______________________________
Please rate helpful posts and answered questions!
Joel _______________________________ Please rate helpful posts and answered questions!
Yes, access with  RDP, but there is a task that requires connecting through clienless vpn to different servers are also available to local HDD client PC.
I implemented it by adding the connection "rdp://servers?RedirectDrives=TRUE", but it is uncomfortably for end users, as it is possible to solve the problem without having to manually specify this option?
Thanks in advance.
try redirecting this trough https it  might work.
when modifying the bookmark instead selecting RDP try to select http/https and try to put this
XXX.XXX.XXX.XXX/?RedirectDrives=true&RedirectPrinters=true
