AnyConnect SBL on windows 8
Answered Question
Nov 26th, 2012
Has anyone got AnyConnect option Start before Logon to work on windows 8 Pro?
///Fredrik
Correct Answer by Javier Portuguez about 4 years 2 months ago
Hi Fredrik,
AnyConnect Support for Windows 8
AnyConnect 3.0.10055 and later versions (including the latest version of AnyConnect, version 3.1.01065), function on Windows 8 32-bit and Windows 8 64-bit operating systems, though there are some limitations.
So, if the above is true and the SBL settings are properly configured, then it should be functioning.
May I know what exactly is not working for you?
Thanks.
Please rate any helpful posts
Portu.
Overall Rating: 3 (2 ratings)
Correct Answer
Javier Portuguez Mon, 11/26/2012 - 06:50
Hi Fredrik,
Thanks.
Portu.
carlosrua28 Mon, 10/21/2013 - 14:20
I have Windows 8.1 with the AnyConnect version 3.1.04072 installed. I have the SBL box checked but it is still not visible when I click Other User in the login screen. Please help.
cyr0nk0r1 Wed, 11/13/2013 - 11:31
I'm also having the same problem. Where is the Cisco documentation that deals with AnyConnect 3.1.04072 and Windows 8/8.1 SBL?
Eric Shade Mon, 11/18/2013 - 13:08
The known issues with AnyConnect are documented in the release notes, here:
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect31/release/notes/anyconnect31rn.html#AnyConnect_Support_for_Windows_8
Issues found since the last release are listed in the Bug Toolkit, which is here:
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
Configuring SBL is documented in the AnyConnect Administrators Guide, here:
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect31/administration/guide/ac03vpn.html#Configuring_Start_Before_Logon
If you are still having problems with SBL on Windows 8.1, please contact Cisco support.
Eric
Related Content
