Anyconnect 3.1 - The certificate on the secured gateway is invalid
Answered Question
Nov 27th, 2012
Hi guys,
I have a problem with the Anyconnect 3.1.01065.
When I try to connect I get the "The certificate on the secured gateway is invalid. A VPN connection will not be established".
The Certificate is a self signed cert.
Anyconnect 2.5 woks without problems.
ASA image: 8.4(2).
[27.11.2012 15:58:27] Ready to connect.
[27.11.2012 16:01:49] Contacting IP_WAN.
[27.11.2012 16:01:52] Please enter your username and password.
[27.11.2012 16:02:01] User credentials entered.
[27.11.2012 16:02:02] Establishing VPN session...
[27.11.2012 16:02:03] Checking for profile updates...
[27.11.2012 16:02:03] Checking for product updates...
[27.11.2012 16:02:03] Checking for customization updates...
[27.11.2012 16:02:03] Performing any required updates...
[27.11.2012 16:02:08] Establishing VPN session...
[27.11.2012 16:02:08] Establishing VPN - Initiating connection...
[27.11.2012 16:02:09] Disconnect in progress, please wait...
[27.11.2012 16:02:13] Connection attempt has failed.
Has anyone had this issue before?
Thanks a lot.
Correct Answer by Javier Portuguez about 4 years 6 months ago
Hi Cristian,
Please check this out:
CSCua89091 Bug Details
the local CA needs to support EKU and other necessary attributes
Symptom:
Currently the local CA server on the ASA doesn't support attributes like the EKU. This enhancement request is to add support for that.
Workaround:
configure cert matching on client profile
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCua89091
And the following:
DOC: Anyconnect supports specific Extended Key Usage attributes in certs
Symptom:
When using certificates with the anyconnect client if the certificate installed on the ASA doesn't have the EKU attribute set to "server-authentication" then the anyconnect client will reject the ASA's certificate as invalid. Similarly the client's id certificate also needs to be "client-authentication" otherwise the ASA will reject it..
Conditions:
Use an id certificate on the ASA that has an EKU other than "server-authentication".
Use an id certificate on the client that has an EKU other than "client-authentication".
Workaround:
Generate a new ID certificate with the correct Extended Key Usage
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCty61472
So at this point you would need to configure certificate matching or use a previous version of the AnyConnect client.
HTH.
Please rate any helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Javier Portuguez Tue, 11/27/2012 - 07:24
  • Red, 2250 points or more
Hi Cristian,
Symptom:
Workaround:
And the following:
Symptom:
Conditions:
Workaround:
HTH.
Cristian Iconaru Tue, 11/27/2012 - 07:51
great!
I was on the same page trying to figure it out .
so basically the profile must be configured on the client PC to match the ASA self signed cert attributes.
I only have the hostname defined in the cert.
Status: Available
  Certificate Serial Number: 111111
  Certificate Usage: General Purpose
  Public Key Type: RSA (1024 bits)
  Signature Algorithm: SHA1 with RSA Encryption
  Issuer Name:
    hostname=ASA-FW
  Subject Name:
    hostname=ASA-FW
  Validity Date:
    start date: 00:53:06 CEDT Apr 17 2012
    end   date: 00:53:06 CEDT Apr 15 2022
  Associated Trustpoints: SSL-Trustpoint
which attribute will it be?
Thanks.
Javier Portuguez Tue, 11/27/2012 - 08:09
Hi Cristian,
You could check for the CN value in the certificate:
CN
ASA-FW
HTH.
Cristian Iconaru Wed, 11/28/2012 - 01:57
I've tried it with the following profile but it doesn't work. same error.
<?xml version="1.0" encoding="UTF-8"?>
http://schemas.xmlsoap.org/encoding/">
            CN
            ASA-FW
Thanks.
Cristian Iconaru Wed, 11/28/2012 - 02:11
what do you think? should i generate a new self signed cert?
this one is pretty basic.
crypto ca trustpoint SSL-Trustpoint
enrollment self
keypair sslvpnkeypair
crl configure
it has no CN/FQDN/etc..only "Issued to", "Issued by" and the keys.
Thanks.
Cristian Iconaru Wed, 11/28/2012 - 03:31
I added the CN, regenerated the cert, changed the Anyconnect profile and it works!
Thanks a lot!
Cristian Iconaru Wed, 11/28/2012 - 05:08
short question.
Is there a way to disable the warning generated from using self signed certs?
I would like to make the process as seamless as possible.
Thanks.
Javier Portuguez Wed, 11/28/2012 - 07:25
Hi Cristian,
For this message to go away, you need to install your ASA certificate on each machine (you can do it through the web browser).
HTH.
Portu.
Cristian Iconaru Thu, 11/29/2012 - 00:16
Hi Portu,
I've just tried, the connection works but the warning keeps coming.
- CN=abc.example.com
- DNS - abc.example.com resolves to ASA_IP
- CN matches the DNS
- Certificate was installed on client PC
Where does the Anyconnect search/check for the certs?
Thanks.
Cristian Iconaru Fri, 11/30/2012 - 05:21
Hi Portu,
I tried with a trial cert from Thawte but the warning keeps coming.
any idea why?
Thanks.
