ACE NAT Pool on different Network.
Nov 28th, 2012
Can the Nat Pool be on a different network that the load balanced vip?  My current design uses nat pool on the same network, but the archatect wants the NATs on seperate VLAN.
I will be developing on ACE MOD20, but the final configuration will be on 4710.
chrhiggi Wed, 11/28/2012 - 10:53
  • Silver, 250 points or more
Sure can, however,the point of source NAT is generally that the source IP should be L2 adjacent to the server.  If the source IP is not, then you have to have a static route in your server or somewhere in the network to ensure the traffic makes it back into the same interface vlan on ACE. In that case... you might as well not use nat and put routes on the server for the client subnets.
Chris Higgins
geraldjacksontx Thu, 11/29/2012 - 04:41
I am using Load Balancer on a stick.  So I can create a VIP or class map on one subnet (SVI) and NAT Pool on another (SVI) or do I need 2 SVI.  I currently do it under a single network on (SVI).
Can you send me an example?
I need the VIP/class map to not be L2 adjacent.  I will not own the routing.  It will be done by another contractror.  But if I I use a second Network for NAT Pool then the routing, with default routing on the servers should work.
chrhiggi Thu, 11/29/2012 - 10:30
Cecil-
rserver host Esc1
  ip address 172.16.36.132
  inservice
serverfarm host HTTP
  rserver Esc1
    inservice
class-map match-all 172.16.36.13-80-VIP
  2 match virtual-address 172.16.36.13 tcp eq www
policy-map type loadbalance first-match 172.16.36.13-80-PMAPLB
  class class-default
    serverfarm HTTP
policy-map multi-match GLOBAL-PMAPVIP
  class 172.16.36.13-80-VIP
    loadbalance vip inservice
    loadbalance policy 172.16.36.13-80-PMAPLB
    nat dynamic 1 vlan 190
interface vlan 190
  ip address 172.16.36.12 255.255.255.192
  access-group input test
  nat-pool 1 192.168.1.1 192.168.1.1 netmask 255.255.255.0 pat
  service-policy input GLOBAL-PMAPVIP
  no shutdown
For this sample, the source ip of the traffic as it left the ACE would be 192.168.1.1, off subnet of vlan 190 as you are requesting.  As well, the server in the example is not L2 adjacent to vlan 190, but it could be either way.
Chris
Related Content
