11-29-2012 07:15 AM
Coming from IOS, looking to implement the following RADIUS commands under IOS-XR and have not found how to do so yet.
Anyone know?
radius-server attribute 6 on-for-login-auth
radius-server attribute 32 include-in-access-req
TIA,
12-03-2012 07:00 AM
Garry,
both are natively sent in XR, you don't need to specify that explicitly (fortunately ).
Here an example access-request from 9K/XR
Mon Dec 3 09:44:18 2012: [7068] message received from 3.0.0.233/55223.37 code=1, length=264
Mon Dec 3 09:44:18 2012: [7068] Cisco-avpair = "if-handle=52512"
Mon Dec 3 09:44:18 2012: [7068] Cisco-avpair = "client-mac-address=0019.2f43.9a38"
Mon Dec 3 09:44:18 2012: [7068] NAS-Port = 67109347
Mon Dec 3 09:44:18 2012: [7068] NAS-Port-Id = "."
Mon Dec 3 09:44:18 2012: [7068] Vendor-Specific-9-2 = "."
Mon Dec 3 09:44:18 2012: [7068] User-Name = "dialer"
Mon Dec 3 09:44:18 2012: [7068] Service-Type = Framed-User
Mon Dec 3 09:44:18 2012: [7068] CHAP-Password = "\237>\274\376\2724Z_D\037\0322\315\363]\330\267"
Mon Dec 3 09:44:18 2012: [7068] CHAP-Challenge = "\222^N.*VF\230F\257*:\261\310R\377"
Mon Dec 3 09:44:18 2012: [7068] Acct-Session-Id = "0000007f"
Mon Dec 3 09:44:18 2012: [7068] Unknown-196 = "\000\000\000A"
Mon Dec 3 09:44:18 2012: [7068] Cisco-avpair = "connect-progress=LCP Open"
Mon Dec 3 09:44:18 2012: [7068] Framed-Protocol = PPP
Mon Dec 3 09:44:18 2012: [7068] Cisco-avpair = "parent-if-handle=1248"
Mon Dec 3 09:44:18 2012: [7068] NAS-Port-Type = 36
Mon Dec 3 09:44:18 2012: [7068] Event-Timestamp = 1354546634
Mon Dec 3 09:44:18 2012: [7068] NAS-Identifier = "A9K-BNG"
Mon Dec 3 09:44:18 2012: [7068] NAS-IP-Address = 3.0.0.233
Xander
Principal Engineer, ASR9000
Cisco Systems
12-04-2012 09:47 AM
Hm - thanks Xander.
I posted the note as I noticed the incoming REQ much differently.
I'm seeing this minimal REQ from my 9001 running 4.2.3 for router VTY access.
I'm using Radiator as a server.
I edited the Calling-Station-ID and User-Password fields below below for privacy.
Code: Access-Request
Identifier: 46
Authentic: <0><0><4><143>cerrno/libra
Attributes:
User-Name = "test"
NAS-IP-Address = 10.10.10.3
NAS-Port = 130
NAS-Port-Type = Virtual
Calling-Station-Id = "
User-Password =
12-04-2012 04:11 PM
aha! garry I missed the fact that you were referencing an exec login.
I see the same issue. it is a miss. we should include service-type hands down and nas-identifier would be nice to have as well.
I am checking in with our AAA development for XR to make see if this is already recognized as a known issue and if not I will file a ddts to have this corrected.
I don't believe this should be knobbed (like IOS) and just be inserted regardless.
If you don't hear from me by Friday, please send me a reminder and I will let you know the ddts ID that we'll use for tracking. You can use your account team and TAC then to follow up for integration and status.
sounds good?
thanks
Xander
Cisco Systems
12-04-2012 05:36 PM
Xander,
Appreciate the quick verification and avoiding having to work through a TAC case.
I'm just getting used to IOS-XR but might the resolution arrive in a XR module and perhaps more quickly than awaiting it to be folded into a maintenance release (?). Either way sounds good and thanks again.
12-04-2012 06:01 PM
Garry,
Let me see what the scoop of this is from a code perspective, so I can advice better on what the next course of action is.
If this is a show stopper for your deployment, we have a concept of a "SMU" (software maintenance update) which is a package that you can apply to your existing release. So you don't have to go through another certifcation cycle.
Depending on the deployment, timelines, schedules, code complexity etc, we can make something work.
Lets sync up in a few days when I know more and I can advice the right course of action.
If we do go down the smu path, we may need a tac case for reference/linkage, but I'll talk you through that as we go.
Also, if you are new(er) to XR and you like to read up more on this, I have a few white papers that you may like on XR and ASR9000: https://supportforums.cisco.com/docs/DOC-22848, check out the linked documents for more info on route scale, loadbalancing, EVC, L2, L3 etc.
cheers
Xander
Cisco Systems
12-20-2012 01:27 PM
Xander,
Curious if you've had any developer response yet. Is not a show-stopper per-se as local accounts can be used, but prefer things to be in line with other Authentication as these boxes roll into production.
I'm familiar with SMU, but have not loaded any outside the main image yet.
12-20-2012 02:17 PM
Gary, I had requested your SE's to contact you wth the latest info since I didn't have your email, but
last status is that I have a DDTS for you: CSCud59174: Access-request missing service-type for exec authentication
that is slated for XR4.3.1
regards
xander
04-10-2013 11:38 AM
Xander,
Here in April, I'm actually still awating code containing the resolution of this Radius bug.
Any sense of when we'll see 4.3.1 or 4.3.2?
There still doesn't appear to be an SMU for it either unless I'm missing it.
thanks for any info,
04-10-2013 12:14 PM
Garry, I guess your account team missed to update you as I had requested to them.
When you raised the issue I filed a ddts and fixed it for XR4.3.1
That release is due this month. So when you pick up that release, your fix will be in there:
CSCud59174 http://wwwin.cisco.com/ops/infra/pds/cbms/cdets/legend.shtmlAccess-request missing service-type for exec authentication
xander
04-10-2013 12:57 PM
great, thanks for the update.
01-03-2013 05:27 AM
Hi Xander what do you do...
I have some questions about the access-requets from 9K you have showed
I have been analyzing the following,
The value of this Nas-Port 67109347 gave me a result in binary 00000100000000000000000111100011
where in case the nasport type were 5, I would assume this following correlation
slot: 0 0000
subslot: 0 0
port: 4 100
svlan: 0 00000000
cvlan: 483 0000000111100011
and in case the nasport type were 15, I would assume this correlation
slot: 0 0000
subslot: 0 0
port: 4 100
vp: 0 000000000000
vc: 483 000111100011
So, my question is.... Was the original test made on port 0/0/4?
if the answer regarding this is negative,… could you show me the format that you configured for NAS-Port-Type 36?
Thanks.
Javier
01-03-2013 06:08 AM
Hey Javier,
the config used for that example was:
aaa radius attribute nas-port format e SSAAPPPPQQQQQQQQQQVVVVVVVVVVUUUU
Interface: Bundle-Ether100.30.pppoe788
Nas-Port: 67109348
User name: dialer
S S A A P P P P Q Q Q Q Q Q Q Q Q Q V V V V V V V V V V U U U U
0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 0 0 1 0 0
(the formatting is not coming off to nice)
U = 0100 = 4
V = 11110 = 30
Q = 0 = 0
P = 0100 = 4
A = 0 = 0
S = 0 = 0
U = sessionID = 788 = 1100010100 (only last 4 bits used in this format)
V = vlan = 30 = 11110 (matches)
P = port = 4, the 4th bundle ether configured:
interface Bundle-Ether100.2
interface Bundle-Ether100.10
interface Bundle-Ether100.20
interface Bundle-Ether100.30 <<
interface Bundle-Ether100.50
interface Bundle-Ether100.100
slot = 0 (RSP based session, bundle ether)
adapter = 0 (RSP based session, bundle ether)
I noticed an issue here btw, the Q is not filled out properly with the outter vlan...
xander
01-11-2013 09:50 AM
Hi Alexander Thuijis,
I would like to ask one question related to radius when I read through this discussion. In ASR 9000 XR, is any commands available to configure generic authentication parameters for clients using 802.1x EAPOL ??
01-11-2013 09:51 AM
Unfortunately, a9k doesn't do dot1x or EAP.
xander
