UCCX IP Phone Agent State Question
When using IP phone agent there is a system parameter to have the default agent state after a Ring-No-Answer event to default to Ready or Not Ready (it's not ready by default).  Is there a way to alter this behavior at any level other than system wide?    I need this to happen only for specific phones (or it could be at the CSQ or group level).  I do NOTwant to change the behaviors system wide.
Failing that, is there any way or any other place where I can force an agent state to ready after a ring-no-answer (scripting or other)?
NOTE: The IP agents are loggin in using the one-button technique rather than the default BIPPA method.
--Chris
Chris Deren
Chris,
Unfortunately, System level is the only way.
HTH,
Chris
Chris Deren
Chris,
HTH,
Chris
That's what I thought, but I wanted to see if anyone had a work around.  Thanks!
