PIX 515E unable to ping outside from inside
Dec 2nd, 2012
Dear all,
I' d like to have some support for a very-basic PIX firewall configuration.
I 'm dealing with  PIX 515E.
Inside hosts can ping inside interface , outside hosts outside interface and so on...
Simply i cannot ping outside interface from inside hosts,
Inside host-192.168.1.0
Outside - any host like google.com, or to check my isp link's dns ip.
I have attached the pix configuration text file to test and please suggest what i did wrong.
Thanks.
Pankaj.
Overall Rating: 4 (1 ratings)
Jouni Forss Sun, 12/02/2012 - 23:22
Try adding the configuration "fixup protocol icmp" to the configuration and try the ICMP again
- Jouni
cadet alain Mon, 12/03/2012 - 00:49
are you trying to ping outside hosts or the outside interface of the Pix , if this is the latter then it's impossible by design
and as far as i know there is no way to work around this.
Regards.
Alain
kiranthakur Wed, 12/05/2012 - 00:58
Thanks for your reply cadet alan,
I am simply trying to ping my isp's dns server to check the internet link is up or not, or simply trying to ping www.google.com, like sites, before few weeks this was working fine, i was getting reply from all this things, but after doing some modifications in cisco pix515e by one of the enginner, i am facing this issue.
julomban Mon, 12/03/2012 - 12:48
Hello Kiran,
The PIX/ASA only responds to ICMP  traffic sent to the interface that traffic comes in on; you cannot send  ICMP traffic through an interface to a far interface.
This apply for ICMP and management access to the unit, only ping or access will work to your direct connect interface.
Juan Lombana
Please rate helpful posts.
kiranthakur Wed, 12/05/2012 - 01:11
Hi all,
Thanks all for the valueable reply's.
last time i have done modification with following commands to access cisco pix 515e from telnet from outside interface:
access-list outside_access_in permit icmp any any
access-list outside_access_in permit ip any any
access-list inside_access_out permit ip any any
access-list inside_outbound_nat0_acl permit ip 192.168.1.0 255.255.255.0 192.168.168.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 192.168.1.0 255.255.255.0 192.168.80.0 255.255.255.0
access-list outside_cryptomap_30 permit ip 192.168.1.0 255.255.255.0 192.168.80.0 255.255.255.0
access-list 100 permit tcp any eq telnet host PIX_inside eq telnet
access-list 100 permit tcp any eq telnet host pix_outside eq telnet
access-list 100 permit tcp any eq telnet host 182.73.110.160 eq telnet
after adding the above commands i am facing this, my internet link is up and working fine, but not able to get ping reply from internet isp or dns server ip, i.e- 202.56.230.5.
Muhammed Safwan Wed, 12/05/2012 - 01:16
When you modified the outside interface ACL ,you have not permitted the ICMP. Try adding below command .It should work.
access-list 100 permit icmp any any
Pls rate the post if its helpful.
With Regards,
Safwan
Jouni Forss Wed, 12/05/2012 - 01:19
Also,
To my understanding just adding the "fixup protocol icmp" to the configuration should allow the echo-reply messages back to the LAN host even though you have not opened ICMP on the outside ACL.
Did you add the "fixup" command earlier?
- Jouni
kiranthakur Wed, 12/05/2012 - 01:55
Hi Jouni,
I hav'nt added "fixup" command earlier, as linkis live and in use by the users, to avoid any interuption i hav'nt added, once the link is free i will try your suggestion.
THanks for your reply.
Jouni Forss Wed, 12/05/2012 - 02:05
It shouldnt affect your current network operation at all but if you want to be on the safe side while making changes thats understandable.
You could then go with Safwans suggestion/solution then thats above. Which is to open the ICMP in the access-list you have enabled on your outside interface at the moment.
As Safwan says, It does seem you have changed the ACL that you are using on the outside interface at some point.
access-group 100 in interface outside
- Jouni
kiranthakur Wed, 12/05/2012 - 20:30
Thanks Jouni, safwan, Juan Lombana, alain..
All your feedback was very helpful, the command:
is very helpful in my configuration, now i am able to send echo and check my internet's link, or to check other outside ip's.
Thanks All..
Regards.
Related Content
