12-03-2012 06:17 AM - edited 03-21-2019 06:41 AM
How do you install a SSL certificate onto the UC560 for the SSL VPN? I have been trying to use the SSL VPN and getting certificate not valid errors, which I would like to remove by installing my companies wildcard cert on the system. I have looked all through CCA and I can't seem to find anywhere to upload the cert, yet on the SSL VPN window there is a SSL cert selection dropdown.
Greg
Solved! Go to Solution.
12-04-2012 01:47 PM
Here's a method of installing a cert using IOS CLI.
My method creates a trust point called VOIP-TRUSTPOINT, so you'll want to change this to fit your requirements.
Hope this helps
Adam
12-04-2012 01:47 PM
Hope this helps
Adam
