ISE Client Posture Policies
Answered Question
Dec 4th, 2012
                   Hi!
Anybody knows how to configure Cisco ISE Posture Policy to check windows Service Pack? For example, we need to create a policy to check if machine has a Antivirus and the last service pack installed. The policy for antivirus it's simple, but we don't know how to configure for Service Pack check.
Thanks!
Correct Answer by jw.sl9 about 4 years 4 months ago
For those specifc examples, no.  They are pc_  = pre configured from Cisco.
If you want to modify them, you will need to adjust the Value to match what you need.
As always, remember that Registry Valures are CasE SenSITIve.  :-)
I find it best to export the reg key area I need and copy-paste leaving out the " Quotation marks"
Policy > Policy Elements > Condidtions > Posture > Registry Condition
  • pc_W7_SP0
  • pc_W7_SP0_int
  • pc_W7_SP1
  • pc_W7_SP1_int
Use those or duplicate them and modify as you need.
Overall Rating: 5 (2 ratings)
Correct Answer
jw.sl9 Tue, 12/04/2012 - 11:02
  • pc_W7_SP0
  • pc_W7_SP0_int
  • pc_W7_SP1
  • pc_W7_SP1_int
Mafiaboy401 Tue, 12/04/2012 - 11:10
Do we need to create the registry condition?
What is the Registry Type, Registry Root Key, Sub-key and Value Operator to check?
Thanks.
Correct Answer
jw.sl9 Tue, 12/04/2012 - 12:40
Related Content
