GRE OVER IPSec vpn
gaurav bhardwaj
ACC
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009438e.shtml#diag
this is lab i did, today,and  offcouse i am able to understand this lab bus the confusion are
1 . why we use crypto map on both interface (phiycal interface or tunnel interface)
2.  when i remove crypto map from tunnel interface i recieve this message
( R2691#*Mar  1 01:12:54.243: ISAKMP:(1002):purging node 2144544879 )
   please tell me what is meaning of this message
3.But i can see vpn is working fine. this is cryto sa and crypto isakmp sa
R2691#sh crypto ipsec sa
interface: Serial0/0
    Crypto map tag: vpn, local addr 30.1.1.21
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (30.1.1.21/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (10.1.1.1/255.255.255.255/47/0)
   current_peer 10.1.1.1 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 65, #pkts encrypt: 65, #pkts digest: 65
    #pkts decaps: 66, #pkts decrypt: 66, #pkts verify: 66
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 2, #recv errors 0
     local crypto endpt.: 30.1.1.21, remote crypto endpt.: 10.1.1.1
     path mtu 1500, ip mtu 1500, ip mtu idb Serial0/0
     current outbound spi: 0xDBF65B0E(3690355470)
     inbound esp sas:
      spi: 0x44FF512B(1157583147)
        transform: esp-3des esp-md5-hmac ,
        in use settings ={Tunnel, }
        conn id: 5, flow_id: SW:5, crypto map: vpn
        sa timing: remaining key lifetime (k/sec): (4598427/3368)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 6, flow_id: SW:6, crypto map: vpn
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
R2691#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id slot status
30.1.1.21       10.1.1.1        QM_IDLE           1002    0 ACTIVE
IPv6 Crypto ISAKMP SA.
4 . how do i know it is useing GRE over IPsec.
i am also attach my topology on which i did lab
anujsharma85
As far as what I can recall, in older codes it was required to have crypto map on both tunnel and physical interface but now it is not.
Since we are using GRE over IPSEC, thus for verifying the tunnel I will do the following steps:
1.) check if tunnel interface is up. "show ip int br"
2.) check if tunnel statistics are increasing and packets are traversing across it. "show interface"
3.) Verify if crypto ACL includes only interesting traffic listed as GRE peers.
4.) If yes, check IPSEC SA statistics. "show crypto ipsec sa"
If all of them are showing correct statistics with respective counters increasing then traffic is passing through GRE and then getting encapsulating in IPSEC.
Hope this helps.
Anuj
anujsharma85
Hope this helps.
Anuj
MR. Anuj here is my config
R7200#sh ip int b
Interface                  IP-Address      OK? Method Status                Protocol
Serial1/0                  10.1.1.1        YES NVRAM  up                    up
Loopback1                  50.1.1.1        YES NVRAM  up                    up
Loopback2                  50.1.2.1        YES NVRAM  up                    up
Tunnel0                    40.1.1.2        YES NVRAM  up                    up
Tunnel1                    40.1.2.2        YES NVRAM  up                    up
Tunnel2                    40.1.3.2        YES NVRAM  up                    up
R7200#sh int tunnel 0
Tunnel0 is up, line protocol is up
  Hardware is Tunnel
  Internet address is 40.1.1.2/24
  MTU 17916 bytes, BW 100 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 10.1.1.1 (Serial1/0), destination 30.1.1.1
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255
  Fast tunneling enabled
  Tunnel transport MTU 1476 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:00:04, output 00:00:04, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     2229 packets input, 213651 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     2292 packets output, 220520 bytes, 0 underruns
     0 unknown protocol drops
my cryto acl
is
access-list 101 permit gre host 10.1.1.1 host 30.1.1.1
As per the config provided, crypto ACL includes local host as 10.1.1.1 while remote host as 30.1.1.1 however interface description shows 10.1.1.1 as serial / physical interface.
Thus, ideally crypto ACL should include traffic as ::
access-list 101 permit gre host host
Anuj
