12-07-2012 01:50 AM - edited 03-10-2019 07:52 PM
I try upgrade ACS 5.3.0.40 to new version 5.4.0.46. Everything looks ok:
ACS-machine/acsadmin# application upgrade ACS_5.4.0.46.tar.gz rep01
Do you want to save the current configuration ? (yes/no) [yes] ?
Generating configuration...
Saved the running configuration to startup successfully
% CARS Install application required post install reboot...
Broadcast message from root (pts/0) (Thu Dec 6 23:36:41 2012):
The system is going down for reboot NOW!
Application upgrade successful
But ACS machine (vmware instance) can't boot with this result: Volume group "smosvg" not found. (for details see attachment)
Any ideas?
martin
Solved! Go to Solution.
12-11-2012 05:17 AM
Did you install patch 8 on the 5.3.0.40 before upgrading to 5.4?
Maybe you are running into CSCuc93106..
edit:
ehhmm .. unlikely.
12-11-2012 05:17 AM
edit:
ehhmm .. unlikely.
12-14-2012 01:36 AM
joopv,
of course I have no patch installed! before upgrade to 5.4 is needed patch 6 or higher (patch 7, 8).
thanks.
martin
01-07-2013 12:18 AM
Hello joopv,
after successfully installing patch 8, upgrade to 5.4 has the same issue - kernel panic after reboot to 5.4. Any idea?
martin
01-29-2014 05:31 PM
Martin,
How much disk space did you allocate for ACS when you initially created the VM?
Javier Henderson
Cisco Systems
01-30-2014 12:36 AM
Javier,
it was long time ago, I can't remember. But I think, there was enough space (based on install/upgrade guide).
In the final, I exported configuration from version 8.3, then install fresh 8.4 and import saved configuration. I had two ACS boxes, therefore whole upgrade was without interuption 'radius services'.
martin
