12-07-2012 04:10 AM
Hello Community,
Can someone please help me compile a script that will alert me when routes have vanished from the a routing table?
Cheers
Carlton
12-07-2012 08:34 AM
Carlton,
This one is a little easier
You could track the route with tracking and then create an event based on that. If you were watching route 10.10.10.0/24, you could do something like the following:
track 1 ip route 10.10.10.0 255.255.255.0 reachability
event manager applet RouteIsGone
event track 1 state down
*** Below is the mail you could send if you wanted to be alerted via email ***
action 1.0 cli command "enable"
action 2.0 mail server "
The above is very brutal but gets the job done. I found another post from Joseph that gives a couple of other solutions.
https://supportforums.cisco.com/thread/2122275
HTH,
John
*** Please rate all useful posts ***
12-07-2012 08:46 AM
You can use the routing event detector for that:
event manager applet ROUTES-ALERT
event routing network 10.0.0.0/8 type all protocol all le 24
action 1.0 syslog msg "Network $_routing_network Mask $_routing_mask Using $_routing_protocol: $_routing_type"
Other parameters available:
$_routing_lastgateway
$_routing_distance
$_routing_time
$_routing_time_sec
$_routing_time_msec
$_routing_metric
$_routing_lastinterface
You can see all the variables populated by an event detector by looking at this command:
show event manager detector routing detailed
12-07-2012 09:03 AM
Arie,
I've been curious....where can I get a listing of the variables that Cisco has? Like the others you posted: $_routing_xxx
12-07-2012 09:10 AM
There is a bunch of global ones which are in the general docs:
For some of the event detectors the easiest way would be to use a show command on the router:
"show event manager detector
12-07-2012 09:14 AM
Thank you!
HTH,
John
12-07-2012 10:15 AM
Chaps,
I have just glanced over the responses and can't thank you enough for you're replies. I have just got home, so not had time to view the replies in detail.
I will review the responses and let you know how I've got on.
Thanks again, gents.....
12-07-2012 10:11 AM
Take a look at "show event manager detector DETECTOR detail" for all of the ED variables. For the action variables, I created this doc to spell them all out:
12-07-2012 12:59 PM
Arie,
I tried to apply your EEM but the device is 3600 and there isn't an IOS available to allow me to run any EEM other than 2.1.
I'm very surprised I can't download an IOS such as 12.4(22)T for 3600's to enable me take advantage of the benefits of EEM 3.0? Can someone explain why that is?
Cheers
12-07-2012 01:40 PM
Well, the 3600 routers hit the last day of support milestone in 2008.
Cisco stopped selling them in 2003.
This is the EOL announcement:
12-07-2012 01:54 PM
Arie,
Would you happen to if I can load IOS 12.4(22)T on 2691 or any of the 2600's?
Cheers
12-07-2012 04:03 PM
If the image fits the flash and loads without crashing, then you are fine for lab and playing around scenarios.
I would not recommend running offically unsupposrted images as you would not be able to get official support
12-08-2012 10:26 AM
As Arie previously pointed out, these are very old devices. They don't have the memory for such new images. The 2691 can only run up to 12.4(15)T, so that gives you EEM 2.3. The same goes for all the 2600 series. If you want EEM 3.0, you will need to move to an ISR router (e.g., 1800 or 2800).
12-08-2012 11:54 AM
Joseph,
Its great knowing that I can get EEM 2.3 on 2691 with 12.4(15)T, however I'm sure I tried in the past and I was only able to get EEM 2.1 even with 12.4(15)T - I will try again....
Cheers
12-08-2012 04:15 PM
Yes, 12.4(15)T contains EEM 2.3. The differences between 2.1 and 2.3 are small, though. You get the "pattern" keyword on CLI actions for applets, the track event detector, the resource (ERM) ED, and the RF ED.
