C20 and SX20 Camera Cable
Answered Question
Dec 7th, 2012
  • Blue, 1500 points or more
Can i use the same cable from C20 Camera on the SX20 Camera?
Leonardo Santana
Correct Answer by Adam Wamsley about 4 years 4 months ago
Hey Leonardo,
Yes the hdmi cable for the TV/Monitors are the same for each codec. The SX20 supports the Visca protocol which is why the camera cable is different. I however have connected a regular HDMI cable between the camera and codec without any issues as far as I can see, but always keep in mind to follow the guides and use the recommended cables.
Adam
Correct Answer by Rafal Szeremeta about 4 years 4 months ago
Hello Leonardo
SX 20 and C series use different connections for the cameras, so that is not possible using supplied cable.
Please check this link:
http://www.cisco.com/en/US/docs/telepresence/endpoint/camera/precisionhd/user_guide/precisionhd_1080p-720p_camera_user_guide.pdf
Thank you
Rafal
Overall Rating: 5 (2 ratings)
Leonardo Tadeu Sat, 12/08/2012 - 19:31
Ok Thanks
And the hdmi cable that connects on tv is the same for C20 and SX20 correct?
Leonardo Santana
Correct Answer
Adam Wamsley Sat, 12/08/2012 - 19:53
  • Cisco Employee,
Hey Leonardo,
Adam
Leonardo Tadeu Sun, 12/09/2012 - 06:56
Thanks Adam
I ll follow the Cisco recomendations.
Leonardo Santana
