IM and Presence Service
Dec 10th, 2012
They say "starting Unified Communications Release 9.0, Cisco Unified Presence is now integrated within Cisco Unified Communications as the IM and Presence Service and provided as part of the core Cisco Unified Communications ordering".
Does this mean we don't have to do any IM/Presence ordering anymore i.e the fuctionality is enabled by default when you get your Jabber enhanced UCL for call control??
Thanks in advance!
Jaime Valencia Mon, 12/10/2012 - 09:37
  • Cisco Employee,
  • Hall of Fame,
    2011
Not sure about ordering, but you still need to install your IM&P server and integrate with CUCM.
What changed, is that most of the config is now done in the CUCM side of the house.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Kelvin Machakaire Mon, 12/10/2012 - 22:36
Can somebody please assist with ordering information. Am configuring a Cisco Unified Communications 9.X Solution for which Cisco Jabber for Windows will be used as the primary phone. It should run voice, video, instant messaging and presence. Problem is I haven't been able to find ordering information for the IM and presence.
Thanks in advance!
Steven DiStefano Tue, 12/11/2012 - 05:54
  • Blue, 1500 points or more
If you only need the single soft client you certainly can use the 9.0 UCL License model, which allows you to operate it as an ENHANCED user license.   Remember to buy UCXN as well for voice mail (remember UCL is a la carte).  The good news is in 9.0 you dont have to buy CUPS license as it is included in Jabber for Everyone.
I think your find everything you need for CUCM and IM&P under this top level part number for 9.0, if you want UCL.
R-UCL-UCM-LIC-K9
Related Content
