12-13-2012 01:52 AM - last edited on 03-25-2019 09:48 PM by ciscomoderator
Hi all,
My customer's system includes CUCM and CUC (Cisco Unity Connection).
I have a situation when I configure in my customer's system
- I configure meet me conference number (1111) in CUCM,
- When I set up meet me conference with number 1111 in internal phones, we can conference well
- I set up meet me conference with number 1111 from internal phone. I have 2 attendees from external phones join to meet me conference, the first they need to dial to my company 's phone number and they will hear opening greeting ("Wellcome to ...., pls press 1 to join meet me conference"). In CUC server, we configure direct routing rules to Opening Greeting, and configure when I press 1 (caller input is 1) , the call is tranfer to alternate Contact number 1111 (Meet me number).
But 2 attendees from external phones can not go to meet me conference.
I just configure like that in my labs and it is okie for external phones
Can you help me to troubleshoot this problem!
Thanks you so much!
12-13-2012 06:34 AM
I'd start by checking codecs and the amount of users you have configured for meet-me
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-13-2012 06:34 AM
On the Opening Greeting call handler do you have "Allow Transfers to Numbers Not Associated with Users or Call Handlers" checked under standard greeting? Otherwise UCXN can only transfer caller to a user defined on it.
HTH,
Chris
12-18-2012 07:32 PM
Hi Chris Deren,
I have "Allow Transfers to Numbers Not Associated with Users or Call Handlers" checked but it is still not work well.
Thanks you so much!
12-19-2012 06:18 AM
Hi there,
Perhaps you are hitting this bug;
Symptom:
Supervised transfers from UC to Meetme number cause call to be taken back to UC instead of transfer due to using the same RTP port.
Conditions:
Observed in CUCMBE 8.6 and 9.x, but may also be present in previous versions as well.
Workaround:
Use release to switch or use an IOS CFB or MTP resource.
8.6(2),9.0(1)
Status:
Fixed
Last Modified:
Sep 30,2012
9.5(0.36),8.6(2.23048.1),8.6(2)ES50,10.0(0.97013.3)
10.0(0.96000.19)
Product:
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
"Far away from your trouble and worry
You belong somewhere you feel free" - Tom Petty
