TelePresence EX60 with CUCM 8.5 - How to Integrate??
Answered Question
Dec 13th, 2012
Good morning people,
I'm building a lab with CUCM 8.5 and Presence Server 8.5
I'll install the Cisco TelePresence EX60, and I wonder how I do the integration with CUCM.
Have any need to install additional server? You simply add a SIP device in CUCM?
Can someone help me??
Thank you
Bruno
Correct Answer by Marius Nedregaard about 4 years 4 months ago
Hi.
You would need to have CUCM 8.6 in order to utlize the full potential of the CUCM / EX60 integration. You register the device directly to the CUCM.
I would recommend you to have a look at this guide after you have proceeded with updating your lab.
http://www.cisco.com/en/US/docs/telepresence/endpoint/codec-c-series/tc5/administration_guide/cts_endpoint_administration_ucm86_quick_start_guide_tc50.pdf
I have attached a screenshot showing how it should look in the device overview page.
//Marius
Overall Rating: 5 (1 ratings)
Correct Answer
Marius Nedregaard Thu, 12/13/2012 - 06:41
  • Cisco Employee,
Hi.
//Marius
brunofalco Mon, 12/17/2012 - 05:02
Hi Marius,
Sorry for the delay, thanks for your help ...
I made an installation of CUCM 8.6 (1) and could register it successfully!
Taking advantage, you know the Cisco TelePresence VX Clinical Assistant??
I need to register it in CUCM 8.6 ... but also do not think much documentation for it ... knows something that can help me?
Tks
Bruno
Andriy Zatyshnyy Mon, 12/17/2012 - 07:31
Hi Bruno!
VX based on C20 codec. So choose it in CUCM 8.6 aka native device.
KR
AZ
brunofalco Mon, 12/17/2012 - 11:03
Hello Andriy,
See the options that I have to create this endpoint.
Have you tested it with some, but without success.
Currently hooked up a router to use as a gatekeeper, also without success.
I added a Gatekeeper in CUCM and a trunk, could not also, see the results:
The IP is 20.20.0.10 of CUCM.
NO VX Clinical I get the following information: "Failed Rejeitado.Encoding RRQ"
Andriy Zatyshnyy Tue, 12/18/2012 - 04:39
Hello Bruno!
Have you registered it with Cisco TelePresence Quick Set (C20)?
KR
AZ
azeem.haider Wed, 07/16/2014 - 06:06
Hi Guyz...
i am trying to Register Cisco VX Clinical Assistant on CUCM 9.
which phone type do i have to Select...?
I have tried Cisco TelePresence Quick Set (C20) but it is not registering.
But when i open the webpage of the codec in VX clinical Assistant it shows EX90 codec.
brunofalco Wed, 07/16/2014 - 06:56
Good day,
At the time I was using version 8.6 of the CUCM.
As there were no way to register VX Clinical, I needed to configure a Gatekeeper, and register it.
That way worked.
Today, in version 9 I do not know if it's possible.
Bruno
azeem.haider Wed, 07/16/2014 - 10:50
what do you mean by configuring the Gatekeeper...
How can i do it...?
Ravi Yadav Wed, 07/16/2014 - 07:14
  • Silver, 250 points or more
Now days the VX clinical is coming with an SX20 Codec
hardware version 1.2
and it supports native registration
use Sx20 instead of c20 .
what is the version on sx20 ?
Ravi kr.
Related Content
