How do you disable administrative native vlan tagging on the 6509?
david.erickson
We have a problem with CDP packets on sent by our Cisco 6509's.  Unlike our other Cisco switches (4948G, 5020, etc.), the 6509 tags administrative traffic on the native vlan.  As a result the CDP packets are sent with an 802.1Q header with a tag of 1.  The other switches send the CDP packets untagged on the native vlan.  This causes problems because we have non-Cisco devices in our lab that also receive and send CDP, but they do not process the packets that are tagged by the 6509.  They see the packets from the 4948 and 5020 just fine.
How can I disable the administrative native vlan tagging on the 6509?  Here is the current setup:
nwkdev-6509-1#show vlan dot1q tag native
dot1q native vlan tagging is disabled globally
nwkdev-6509-1#show interfaces gigabitEthernet 1/9/1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 155 (DATA_VLAN)
Administrative Native VLAN tagging: enabled
Operational Native VLAN tagging: disabled
nwkdev-6509-1#show version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-VM), Version 12.2(33)SXI4a, RELEASE SOFTWARE (fc2)
13 Replies 13
cadet alain
---> so it seems it is disabled
You could do a packet capture to get sure.
Regards.
Alain
The description of the problem is based on packet captures.  6509 tags the CDP packets, 5020/4948 do not.
Can you do a show run on this interface so that we see what your configuration is?
sh run int gigabitEthernet 1/9/1
sh int gigabitEthernet 1/9/1 status
nwkdev-6509-1#sh run int gigabitEthernet 1/9/1
Building configuration...
Current configuration : 190 bytes
interface GigabitEthernet1/9/1
switchport
switchport trunk native vlan 155
switchport mode trunk
mtu 9216
spanning-tree portfast edge trunk
end
nwkdev-6509-1#sh int gigabitEthernet 1/9/1 status
Port         Name               Status       Vlan       Duplex  Speed Type
Gi1/9/1                         connected    trunk      a-full a-1000 10/100/1000BaseT
I don't understand why it would be sending the packets on vlan 1  irregardless because it is not in access mode in order for it to use  this:
In trunk mode, it will always use the native vlan specified on the command switchport trunk native vlan 155.
Yes, I had the same question: "I don't understand why it would be sending the packets on vlan 1"
The show interface switchport does include the access vlan setting:
Perhaps I should set the access mode vlan to 155 so that it matches the trunk native vlan (without changing the mode of
the ports to access), and the problem would go away?
I will try it.
OK, I tried all of these, only the last one results in CDP packets being untagged:
access vlan: 1, native vlan: 155, mode: trunk
access vlan 155, native vlan: 155, mode: trunk
access vlan: 1, native vlan: 1, mode: trunk
So it looks like changing the native vlan of the port to something other than 1 causes the CDP packets to get tagged.
Perhaps there is a global switch configuration command that is missing?  i.e. each of the trunk ports has its native vlan
set to 155, but is there a command needed to tell IOS that vlan 155 is the native vlan for all trunks, including administrative traffic?
try in global config mode :
That would be too disruptive to even try.  Many other users share this switch.  did you mean
no vlan dot1q tag native?
Currently this is disabled. So if you want the native vlan to be tagged on all the trunk interfaces you will need to enable it, no?
Mandlenkosi, I am trying to stop the tagging of CDP packets, not enable it for the native vlan.  Currently all packets on the native vlan are untagged, except for CDP.  CDP is tagged only if the native vlan is something other than 1.
amikat
Level 7
Level 7
The 802.1Q standard mandates that only ONE vlan within a trunk can have untagged frames. This is so called native vlan. With your configuration the native vlan is clearly vlan 155. So for your trunk configuration only  frames within vlan 155 are untagged while ALL other vlans within the trunk carry TAGGED frames. This is true even for vlan 1 so quite correctly you can see vlan 1 frames tagged with the VID of 1. Cdp runs over Vlan 1 (even if this is not the native vlan).
Best regards,
Antonin
On the 5020, running Nexus OS, with the config below, CDP packets are not tagged:
interface Ethernet1/2
on the 6509, running IOS, with the config below, CDP packets are tagged:
interface GigabitEthernet1/4/5
switchport
mtu 9216
end
Even the trunk port that connects the 6509 and the 5020 is configured this way, and both see the other's CDP traffic,
even though the 5020 sends untagged CDP packets.  Similarly,  the 6509 sees all the non-Cisco devices that send
it untagged CDP packets on trunk ports with the same configuration as above, all of which would seem to say that
the 6509 has a configuration problem, it can receive untagged CDP packets, but it cannot send them, unlike other Cisco gear.
