WLC 2504, Multicast Stub & Apple TV
I was hoping that someone has come across the same issues we are experiencing with the Apple TV and WLC.
We currently have a Apple TV and iPhone same subnet connecting via Lightweight AP (different subnet) which connects to a Cisco3750 running IP Base. This connects to WAN routers managed by third party over a WAN and connects to far end Managed routers, these connect to other Cisco3750 IP Base and onto a 2504 Wireless LAN controller. We have used the the following document for WLC configuration;
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_tech_note09186a0080bb1d7c.shtml
We turn on Multicast globaly, with IGMP snooping enabled also enable Multicast Multicast under controller (only option available on 2504) and give the device  MCast address 239.21.1.150 . The P2P blocking action is disabled. Going to Monitor Multicast we can see the Report for 224.0.0.251
and MGID. However the issue is at the Sender Receiver side the iPhone cannot see the Airplay on the iPhone that should be seen if the end to end stream is working.
My focus is now on the Cisco3750's, allthough I do not totally understand why the device needs Multicast enabled as the Multicast Join and Group Traffic is encapsulated in the CAPWAP Tunnel is it not?
Anyway I have enabled the only option "ip multicast routing distributed" and under the Vlans that connect to WLC and AP's the only option available is the "ip pim passive" there is no "ip pim sparese-dense mode"
Any help and assitance on this would be greatly appreciated. I am sure the WLC is configured correctly, but I suspect that this will not work due to the IP Base image on the 3750's not being able to run full multicast or we need to use unicast for this solution that the 2504 does not support.
Darren
Ok,
After further reading, I think I now understand. I previously thought that the CAPWAP protocol would encapsulate the Multicast inside of a unicast packet, however this seems not to be the case as with the following statement from the same URL in the previous update;
"The Cisco Unified Wireless Network (CUWN) supports two methods of multicast distribution to access
points (APs) associated with the controller. In both modes, the original multicast packet from the wired
network is encapsulated inside a Layer 3 CAPWAP packet sent via either CAPWAP Unicast or Multicast to
the AP. Since the traffic is CAPWAP encapsulated, APs do not have to be on the same VLAN as the client
Bonjour traffic."
Therefore as we only have the Multicast Multicast Option using the 2504 WLC the CAPWAP will be a Multicast Packet and requires the Network to support Multicast from Controller to LWAP. As we have IP Base and a WAN to consider we would probably need to implement some kind of tunneling GRE and RP's etc.
Darren
Hi All,
Just as an update, this issue has now been solved. To confirm we have successfully sent the CAPWAP Multicast destined for apple TV via Airplay from source Apple iPad to a Apple TV and displayed Video from Internet on Large Screen TV. We used the well known GRE encapsulation to be able to send the traffic over a IP Enabled MPLS WAN. See the configuration below, this has been tried and tested;
Wireless Client and LWAP End
interface Loopback0
description GRE Tunnel Source Interface
ip address 1.1.1.1 255.255.255.255
no shutdown
interface Tunnel0
description CAPWAP Multicast Traffic Encapsulation
ip address 192.168.1.1 255.255.255.252
tunnel source loopback 0
tunnel destination 2.2.2.2
ip pim sparse-dense-mode
no shutdown
interface vlan [LWAP_Vlan]
ip pim passive
ip mroute [WLC_Management_IP] 255.255.255.255 Tunnel0 [Reverse_Path_Chk_MCast_Source]
ip mroute 2.2.2.2 255.255.255.255 Tunnel0 [Reverse_Path_Chk_Tunnel_Source]
Wireless LAN Controller End
interface Loopback0
ip address 2.2.2.2 255.255.255.255
no shutdown
interface Tunnel0
ip address 192.168.1.2 255.255.255.252
tunnel destination 1.1.1.1
no shutdown
interface vlan [WLC_Vlan]
ip pim passive
ip mroute [LWAP_Managemnt_IP] 255.255.255.0 Tunnel0 [Reverse_Path_Chk_AP_Source]
ip mroute 1.1.1.1 255.255.255.255 Tunnel0 [Reverse_Path_Chk_Tunnel_Source]
art-barrera Fri, 12/21/2012 - 07:52
Cool - just curious.....who was the carrier with the MPLS offering? I know a couple of the big ones have their own Multicast support offering (for additional cost) and that would certainly break the path for your multicast tree.  I've used GRE tunnels in the past to "insert" my own routing protocols and get around carrier limitations but never thought about multicast until now.  Thanks!  //art
