How to access Web GUI Management - Router 1921
Dec 18th, 2012
Experts,
Good afternoon, how do I access the router's web gui management?
I already enabled the ip http server and ip https commands
I have a username and password configured
I open a browser session with the ip address:      http://192.168.10.1
But I do not get the management GUI.  I haven't used the GUI in many years, thanks for any feedback.
This is what I get on my browser ( I have java up to date on my PC):
Cisco Systems
Accessing Cisco CISCO1921/K9 "my-router"
Show diagnostic log - display the diagnostic log.
Monitor the router - HTML access to the command line interface at level 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
Show tech-support - display information commonly needed by tech support.
Extended Ping - Send extended ping commands.
QoS Device Manager - Configure and monitor QoS through the web interface.
Thank you
mahmoodmkl Tue, 12/18/2012 - 10:32
can u try using https
Ranbeckycr_2 Tue, 12/18/2012 - 10:45
I forgot to add that I had tried using https as well :-)
I think I might be missing something.
mahmoodmkl Tue, 12/18/2012 - 13:25
i suggest to look also at u r browser proxy settigs
Related Content
