12-22-2012 08:52 AM
In my lab I have only one ESX server. On this server I am running VSM and vCenter (appliance).
I am trying to get 1000v working however everytime I try to migrate my ports I get the following error:
Network configuration change disconnected the host '192.168.0.10' from vCenter server and has been rolled back.
fault.NetworkDisruptedAndConfigRolledBack.summary
It seems that it doesn't like the fact that vCenter lives on the same ESX host as I'm trying to migrate.
Anyone have any ideas how I could get this to work?
I've tried both L2 and L3 mode but have failed with both. I have tried using techniques from the Cisco Cloud Lab L3 tutorial as well as some videos I found on Youtube:
http://www.youtube.com/user/sysadmintutorials/videos?view=0
... But I keep getting stuck in the same place...
My port profile config:
port-profile type ethernet vmware-uplinks
vmware port-group
switchport mode trunk
mtu 9000
switchport trunk allowed vlan 1-3967,4048-4093
no shutdown
system vlan 62
state enabled
port-profile type vethernet Management
vmware port-group
switchport mode access
switchport access vlan 62
no shutdown
state enabled
port-profile type vethernet VLAN_62
vmware port-group
no shutdown
state enabled
svs-domain
domain id 1
control vlan 62
packet vlan 62
svs mode L2
Also, I can never get the VEM to show up in my VSM when I do a 'show mod'...
Any ideas?
03-27-2013 04:23 PM
Ok so before you can migrate anything onto the Nexus 1000v (VSM) you have to make sure it has connectivity to the VEM (Host) with the control vlan. When you do a "show mod" it will show module 1 and 2 as the primary and secondary (if you have an HA) VSM. When you add a host to the VSM they will fill in below that as module 3, 4 and so on. Looks like you have it setup to do L2 in your config. And you say when you do a show mod it doesn't show the current VEM for the host. From what I have read and setup in live environments is you want seperate vlans for control, packet, and management. and seperate vlans for vm servers. I would create different port profiles for vmtraffic and one for your system traffic (management, control, packet). If your VSM cannot talk to the VEM installed on the host across the system uplink they VEM will not be added as a module on your VSM. I don't know how many nics you have on your ESX host, but make one assigned to vmware-uplinks port profile and then assign a seperate one to system-uplinks. This should work I believe if i have typed this in correctly. If you have followed the install sheet for the n1k on cisco's site you might need to confirm that the correct VIB is installed on your ESX host as well that is compatibale with the version of Nexus 1000v you have running. You can download the VIB from your VSM if it's managment is working correctly (on the standard switch) at http://vsm-management-ip. I hope this helps you out.
Example below.
vlan 50
name Servers
vlan 61
name Management
vlan 62
name Control
vlan 63
name Packet
vmware port-group
mtu 9000
switchport trunk allowed vlan 50
no shutdown
state enabled
port-profile type ethernet system-uplinks
vmware port-group
switchport trunk allowed vlan 61,62,63
system vlans 61,62,63
no shutdown
state enabled
vmware port-group
switchport access vlan 61
no shutdown
system vlan 61
state enabled
port-profile type vethernet Control
vmware port-group
system vlan 62
no shutdown
state enabled
port-profile type vethernet Packet
vmware port-group
switchport access vlan 63
system vlan 63
no shutdown
state enabled
port-profile type vethernet Servers
vmware port-group
switchport access vlan 50
no shutdown
state enabled
svs-domain
domain id 1
control vlan 62
packet vlan 63
svs mode L2
