Third Party Video SIP device to 8945
Douglas Oman
HI all,
I have a third party video SIP device (2n Helios Vario) and I am unable to get video on my 894x Series phones, but can on my 99x1 phones. Has anyone been able to get this to work? I'm now kind of in a bind as most of our phones are the 894x phones and they will need to be able to see video from the door intercom.
Thanks in advanced,
Doug
10 Replies 10
stevecullen
I just got a resolution from TAC on this issue.
These settings fixed the issue for 8945 and Jabber clients.
Preferred video codecs:
Choice 1 : H.264
Video codec settings:
Video resolution:  CIF (352x288)
Frame rate: 30fps
Video Bitrate: 384
Video packet size: 1400 Bytes
Advanced RTP settings
H.264 payload type (1): 103
H.264 payload type (1): 124
H.263+ payload type (1): 97
Polycomm Compatible; Yes
Thanks, Worked a treat.
Ben
Thanks, been looking for a while to get this to work.
And now it does!
Jeroen
I configured the Helios with the settings mentioned above but I am still not seeing anything on my 9971 or on the Jabber client.
Hello steve,
Where do i have to change this settings?
and is this for a cucm or cme?
thanx, Dennis Koene
I used the config settings and still see no video on the CP-8945 phone.Your last settings were Advanced RTP settings. My setup page is for advanced SDP settings.  Difference?
The newer firmware on the Helios does have different headings. Here's what I have that is working today
Product Name
2N Helios IP Force
555v3
2.6.0.13.7
The settings have remained the same:
Video Parameters:
Frame rate: 30fps
Video Bitrate: 384
Preferred Video Codecs:
Codec 1: H.264
Codec 2 - 4: NONE
Transmission Quality Settings:
QoS DSCP Value 46
Advanced SDP settings
H.264 payload type (2): 124
H.263+ payload type: 97
Hope that helps
Randy,
Have you got the Helios and the phone in the same device pool . i.e. region?
cheers
Please remember to rate useful posts, by clicking on the stars below.
Unfortunately, I am not administrating the CSM, only the Helios.  I wll pass this info on to the CSM administrator.
Same here, 9971 is fine, 8945 is not...I have 2N Force and Verso both setup and working with 9971 / CME
are you running the 8945 with sccp or SIP firmware?
Is your IP PBX is CUCM or CME ?
I'm using CME and so far tried SCCP firmware on the 8945.
My issue/concern/question is, since the 8945 can support VGA quality video, (640x480) why do we have to set the video to CIF (352x288) ?
Thats a big quality difference, can we not use VGA quality?
I had a feeling thats why it's not working, since the 9971 can only support lower resolutions, I didn't bother trying to go higher, but I bought an 8945 specifically FOR the higher resolution. Now I cant have it ?!?!
