01-02-2013 02:49 PM - edited 03-01-2019 10:48 AM
I cannot load the webpage for my UCS via the cluster IP which was working before a full power down. I can SSH to the cluster IP and see things, but the web site and the GUI aplpication no longer work. I tried a second power cycle to no avail and I have gone in to disable / enable the http and https services, again to no avail.
I'm lost as what might be wrong.
-Ryan
01-02-2013 05:39 PM
Did you try your two FI IP's? You should be able to connect to the active one. Try each, which ever works is active, the other will say it isn't active.
Make sure your http/s options didn't change once up.
My UCS Blog http://realworlducs.com
01-02-2013 11:05 PM
Hi Ryan,
Since you can SSH to the UCSM, can you also connect to the local-mgmt of both the FIs and run the following command to make sure the HTTP service is running
FI-A(local-mgmt)# show pmon state
Sample good outout
BGL-SV-UCS-TEST-B(local-mgmt)# show pmon state
SERVICE NAME STATE RETRY(MAX) EXITCODE SIGNAL CORE
svc_sam_controller running 0(4) 0 0 no
svc_sam_dme running 0(4) 0 0 no
svc_sam_extvmmAG running 0(4) 0 0 no
httpd.sh running 0(4) 0 0 no <<<<< running service
svc_sam_sessionmgrAG running 0(4) 0 0 no
Make sure to check this on both the FI.
./Abhinav
