is the WLC command 'config network web-auth captive-bypass enable' specific to only apple devices?
Jan 4th, 2013
if it is, is there a command to enable captive-bypass for Android operating system devices (smartphones, tablets, etc)?
Scott Fella Fri, 01/04/2013 - 07:57
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
yes... the reason is because the iDevices try to reach a site to know if it has connectivity or not... if the device can't reach that site, it opens the portal page.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
gregsawyer Fri, 01/04/2013 - 08:08
i understand, but we have a need for Android devices too.  they want to access google or the google playstore.  is there a command to enable captive-bypass for Android operating system devices (smartphones, tablets, etc)?
Scott Fella Fri, 01/04/2013 - 08:13
  • Hall of Fame,
    2017 Wireless
No... There is no need. It's an option for apple devices to not present the splash page automatically. It forces the user to open up a browser.
Chris Illsley Fri, 01/04/2013 - 08:15
  • Bronze, 100 points or more
You could use a pre-auth ACL to allow some traffic through without authentication to get around this?
Chris
Stephen Rodriguez Fri, 01/04/2013 - 08:29
  • Purple, 4500 points or more
what are you trying to accomplish?
as Scott said, that command stops the iDevice from automagically popping the spalsh page.  If you don't want the user to have to authenticate, or accept AUP, turn off web-auth on the WLAN.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
gregsawyer Fri, 01/04/2013 - 08:36
no, we do want them to authenticate.  we don't have a problem with the iDevices.  we are all good there.  they are working the way they should with the captive-bypass enabled.
i'm asking about Android devices.  it appears Android attempts to do the same thing.
is the captive-bypass command specific for iDevices, or does it cover all devices that attempt to do the same thing the iDevices do?
Stephen Rodriguez Fri, 01/04/2013 - 08:47
so far as I'm aware it's supposed to suppress any whisper client that is trying to reach out to the interwebs.  Not just the url that iDevices use.
HTH,
Steve
Scott Fella Fri, 01/04/2013 - 08:55
  • Hall of Fame,
    2017 Wireless
This will explian what the command was designed for... again... has nothing to do with Android.
To detect this behavior, the Apple device sends a request to http://www.apple.com/library/test/success.html to see if it gets a response To detect this behavior, the Apple device sends a request to http://www.apple.com/library/test/success.html to see if it gets a response
http://tswireless.wordpress.com/2012/07/17/ise-webauth-with-ios-devices/
If you think your Android device is trying to reach something to verify connection, then figure out what its trying to reach (use a sniffer) and then like Chris mentioned, use a pre-auth acl and see if that helps.  Other than that, don't worry about that command as its specific to Apple.
Scott
gregsawyer Fri, 01/04/2013 - 08:59
ok.  my understanding is that the Android devices try to reach something at google but that list of URLs is long and ever changing.  that's the problem with using the pre-auth ACL.
Scott Fella Fri, 01/04/2013 - 09:02
  • Hall of Fame,
    2017 Wireless
Well there is nothing that is going to support that.  I have a couple Android device that connects fine to any WebAuth, I just have to manually open a browser and login.  The command you specified is strictly for Apple.
Scott
Stephen Rodriguez Fri, 01/04/2013 - 09:07
The command stops a whisper client from popping up and forcing you to open a browser.
But it doesn't stop any app that is trying to access the internet.  So it's not 'specific' to apple but to my knowledge, iDevices are currently the only devices doing this.
If someone decided to rewrite a rom for android and add this functionality in, it would block them as well.
HTH,
Steve
gregsawyer Fri, 01/04/2013 - 10:11
thank you all.  this is some very good information.
i posed the question to rule it out as to why we are having issues with android devices connecting.  we installed and are testing an Aruba ClearPass and the Android devices are giving us a problem.  i believe the issue is with the Aruba ClearPass box but at least this re-affirms my suspesion as to it being the Aruba ClearPass
gregsawyer Fri, 01/04/2013 - 10:30
apparently there was a bug in the Aruba ClearPass QuickConnect app.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
