CME SIP Trunk Config debug?
DrVoIP
I am configuring a SIP trunk on a CME.   The configuration is very straight forward, but I am clearly doing something wrong.   Generally, if you enter "debug CCSIP all"  just before you enter the credentials for the SIP SERVER, you can watch the sip registration process. When I do it I get no action, nothing happens?
sip-ua
credentials username TEST password TEST realm cheapvoice.com
generally when you run debug you will see the registraiton attempt as soon as you type the carriage return in the credentials statement?
How do I force a registraiton attempt?  Here is full conifguration
Current configuration : 5448 bytes
version 12.4
hostname LabCME
boot-start-marker
boot-end-marker
enable secret 5 $1$j9K.$l2bbD6kjVGPxXc.5uRa0q.
no aaa new-model
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.1.200.1 10.1.200.10
ip dhcp pool ITS
   network 10.1.200.0 255.255.255.0
   option 150 ip 10.1.200.1
   default-router 10.1.200.1
ip dhcp pool voice
ip domain name DrVoIP.Local
ip host did.voip.les.net 64.34.181.47
voice-card 0
no dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  registrar server expires max 1200 min 300
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
source-address 10.1.200.1 port 5060
max-dn 20
max-pool 10
authenticate realm 172.16.0.0
dialplan-pattern 1 1.. extension-length 3
tftp-path flash:
create profile sync 0071835289771102
voice register dn  1
number 201
call-forward b2bua busy 100
call-forward b2bua noan 100 timeout 20
name Peter
label Bria
voice register dn  2
number 200
name Peter
label CIP
voice register template  1
voice register pool  1
id mac 0026.BB01.512A
number 1 dn 1
max registrations 36
username 7604442665 password 7289
voice register pool  2
id mac 0023.1247.A924
number 1 dn 2
username bria password 7289
voice translation-rule 1
rule 1 /\(^9\)/ //
voice translation-profile DiscardDigit9
translate called 1
username DrVoIP password 0 !@#$%^&
username user1 password 0 cisco
controller T1 0/0/0
framing esf
linecode b8zs
interface Loopback0
ip address 10.1.2.1 255.255.255.0
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
description datanetwork
encapsulation dot1Q 1 native
ip address 172.16.1.2 255.255.255.0
interface FastEthernet0/0.200
description voicenetwork
encapsulation dot1Q 200
ip address 10.1.200.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Service-Engine1/0
ip unnumbered Loopback0
service-module ip address 10.1.2.254 255.255.255.0
service-module ip default-gateway 10.1.2.1
ip default-gateway 172.16.1.1
ip route 0.0.0.0 0.0.0.0 172.16.1.1
ip route 10.1.2.254 255.255.255.255 Service-Engine1/0
ip route 172.16.0.0 255.255.0.0 172.16.1.1
ip http server
no ip http secure-server
tftp-server flash:P00307020200.bin
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.sb2
tftp-server flash:P00307020200.sbn
tftp-server flash:P00403020214.bin
tftp-server flash:P0030702T023.bin
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.sbn
tftp-server flash:P00405000700.bin
tftp-server flash:P00405000700.sbn
control-plane
dial-peer voice 1 voip
description sip trunk to les.net
translation-profile outgoing DiscardDigit9
destination-pattern 9T
voice-class codec 1
session protocol sipv2
session target dns:did.voip.les.net
dtmf-relay rtp-nte sip-notify
no vad
dial-peer voice 2 voip
destination-pattern 600
b2bua
session target ipv4:10.1.2.254
dtmf-relay sip-notify
codec g711ulaw
no vad
sip-ua
credentials username 2316859993 password 112E4E574F4B realm did.voip.les.net
authentication username 2316859993 password 045C015257361A541D011016 realm 64.34.181.47
authentication username 2316859993 password 047C5C545778 realm did.voip.les.net
calling-info pstn-to-sip from number set 7025532706
no remote-party-id
retry options 0
registrar dns:did.voip.les.net expires 3600
sip-server dns:did.voip.les.net
telephony-service
load 7910 P00405000700
load 7960-7940 P0030702T023
max-ephones 5
max-dn 20
ip source-address 10.1.200.1 port 2000
auto assign 1 to 5
voicemail 600
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 100
call-forward busy 600
call-forward noan 600 timeout 18
ephone-dn  2  dual-line
number 101
ephone-dn  3  dual-line
number 102
ephone-dn  4  dual-line
number 103
ephone-dn  5  dual-line
number 104
ephone-dn  11
number 800
mwi on
ephone-dn  12
number 801
mwi off
ephone  1
no multicast-moh
mac-address 000C.29AE.9BAC
type CIPC
button  1:1
ephone  2
no multicast-moh
ephone  3
no multicast-moh
ephone  4
no multicast-moh
ephone  5
no multicast-moh
line con 0
exec-timeout 0 0
password cisco
logging synchronous
login
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
Peter Buswell (aka DrVoIP)
http://blog.drvoip.com
http:/drvoip.com/blog
2 Accepted Solutions
ADAM CRISP
Level 4
Level 4
Hi Peter,
the line:
means that the router will attempt to register every 3600 seconds (1hr) so my guess is that there's a previous registration attempt that's in the system that you missed on your debug.
your can check to see whether this is the case by typing
show sip-ua registration status
If you see your username 2316859993 in the table then this has happened.
I'm be inclined to change the registration interval to 120 seconds, to ease your debugging
i.e.
sip-ua
no registrar dns:did.voip.les.net
registrar dns:did.voip.les.net expires 120
Hope this helps
Adam
Yes,
The Service Provider challenges your Register message:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 172.16.1.2:5060;branch=z9hG4bK68CC;received=76.79.152.2;rport=59232
From: <>2316858060@did.voip.les.net>;tag=381184-E58
To: <>2316858060@did.voip.les.net>;tag=as30db920d
Call-ID: 36DD10CC-56CD11E2-80029504-A735D9CA
CSeq: 8 REGISTER
Server: LES.NET VoIP
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
WWW-Authenticate: Digest algorithm=MD5, realm="64.34.181.47", nonce="19a7b086"
Content-Length: 0
So the providers SIP server is programmed with the realm 64.34.181.47 and not "did.voip.les.net"
So program the credientials keywork on your cisco to match:
sip-ua
credentials username 2316859993 password realm 64.34.181.47
ADAM CRISP
Level 4
Level 4
Hi Peter,
the line:
i.e.
sip-ua
Hope this helps
Adam
Adam - Registration status alwasy says no.  Can you see from debug where it fails?
CMEsipLAB#sho sip-ua register st
Line          peer           expires(sec)  registered
2316858060    -1               28            no
CMEsipLAB#
*Jan  6 00:34:27.055: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x467C6EA4,addr=64.34.181.47
% Incomplete command.
CMEsipLAB#
*Jan  6 00:34:57.151: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x46153DC8) with key=[7] to table
*Jan  6 00:34:57.151: //-1/000000000000/SIP/Info/sipSPIGetOutboundHostAndDestHost: CCSIP: target_host : did.voip.les.net target_port : 5060
*Jan  6 00:34:57.151: //-1/000000000000/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
*Jan  6 00:34:57.151: //-1/000000000000/SIP/State/sipSPIChangeState: 0x46153DC8 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
*Jan  6 00:34:57.151: //-1/000000000000/SIP/Info/ccsip_spi_registrar_add_expires_header: Inside ccsip_spi_registrar_add_expires_header for Expires
*Jan  6 00:34:57.151: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
*Jan  6 00:34:57.151: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 39
CMEsipLAB#SIP/Info/act_idle_outgoing_register: In act_idle_outgoing_register
*Jan  6 00:34:57.151: //7/000000000000/SIP/Info/act_idle_outgoing_register:  Send REGISTER to did.voip.les.net:5060
*Jan  6 00:34:57.151: //7/000000000000/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
*Jan  6 00:34:57.151: //7/000000000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x46153DC8 key=36DD10CC-56CD11E2-80029504-A735D9CA
*Jan  6 00:34:57.151: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
*Jan  6 00:34:57.151: //7/000000000000/SIP/State/sipSPIChangeState: 0x46153DC8 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_SENT_DNS)
*Jan  6 00:34:57.151: //7/000000000000/SIP/State/sipSPIChangeState: 0x46153DC8 : State change from (STATE_IDLE, SUBSTATE_SENT_DNS)  to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_SENT_DNS)
*Jan  6 00:34:57.151: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: TYPE SRV query for _sip._udp.did.voip.les.net and type:1
*Jan  6 00:34:57.175: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_a_query: Type A query for did.voip.les.net and type:1
*Jan  6 00:34:57.175: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_a_query: TYPE A query successful for did.voip.les.net
*Jan  6 00:34:57.175: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 42
*Jan  6 00:34:57.175: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_register_set_dns_resolved_address: CCSIP_REGISTER:: Primary registrar DNS resolved addr set to 64.34.181.47:5060
*Jan  6 00:34:57.175: //-1/xxxxxxxxxxxx/SIP/Info/ccsipRegisterStartExpiresTimer: Starting timer for pattern  for 3600 seconds
*Jan  6 00:34:57.175: //7/000000000000/SIP/State/sipSPIChangeState: 0x46153DC8 : State change from (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_SENT_DNS)  to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
*Jan  6 00:34:57.175: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Jan  6 00:34:57.175: //7/000000000000/SIP/Info/sipSPISendRegister: Associated container=0x45D50F64 to Register
*Jan  6 00:34:57.175: //7/000000000000/SIP/Transport/sipSPISendRegister: Sending REGISTER to the transport layer
*Jan  6 00:34:57.175: //7/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
*Jan  6 00:34:57.175: //7/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x46072A7C, addr=64.34.181.47, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x4136C074
*Jan  6 00:34:57.175: //7/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Jan  6 00:34:57.175: //7/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Jan  6 00:34:57.175: //7/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x46072A7C
*Jan  6 00:34:57.175: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x46072A7C, addr=64.34.181.47, port=5060, connId=1 for UDP
*Jan  6 00:34:57.179: //7/000000000000/SIP/State/sipSPIChangeState: 0x46153DC8 : State change from (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)  to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
*Jan  6 00:34:57.179: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:did.voip.les.net:5060 SIP/2.0
Date: Sun, 06 Jan 2013 00:34:57 GMT
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1357432497
CSeq: 8 REGISTER
Contact: <2316858060>
Expires:  3600
Content-Length: 0
*Jan  6 00:34:57.271: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 64.34.181.47:5060
*Jan  6 00:34:57.271: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
*Jan  6 00:34:57.271: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x466AEFDC
*Jan  6 00:34:57.271: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Jan  6 00:34:57.271: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 8 REGISTER
Content-Length: 0
*Jan  6 00:34:57.271: //7/000000000000/SIP/Error/sipSPIHandleAuthChallenge: Error getting credentials
*Jan  6 00:34:57.271: //7/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Class 4xx Method Code 100 received for REGISTER
*Jan  6 00:34:57.271: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_register_free_rcb: Freeing rcb
*Jan  6 00:34:57.271: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_register_reset_dns_cache: CCSIP_REGISTER:: Primary registrar DNS resolved addr reset
*Jan  6 00:34:57.271: //-1/xxxxxxxxxxxx/SIP/Info/ccsipRegisterStartExpiresTimer: Starting timer for pattern 2316858060 for 180 seconds
*Jan  6 00:34:57.271: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[7] removed.
*Jan  6 00:34:57.275: //7/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
*Jan  6 00:34:57.275: //7/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x46153DC8 key=36DD10CC-56CD11E2-80029504-A735D9CA
*Jan  6 00:34:57.275: //7/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Jan  6 00:34:57.275: //7/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 46153DC8
*Jan  6 00:34:57.275: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[7]
Hi Peter,
Here is what I see from the debugs:
Sent:
Max-Forwards: 70
CSeq: 8 REGISTER
Expires:  3600
Content-Length: 0
Received:
CSeq: 8 REGISTER
Content-Length: 0
Looking at the SIP-UA config:
sip-ua
no remote-party-id
retry options 0
It would be good to check with the ITSP why they are sending a 401 unauthorized for the register message we are sending. Possibly looks like an authentication issue but it would be good to confirm from the provider if your sip-ua config is accurate as per the config on their end.
HTH.
Harmit.
Yes,
Received:
CSeq: 8 REGISTER
Content-Length: 0
sip-ua
