Rolf Fischer Mon, 01/07/2013 - 04:19
  • Blue, 1500 points or more
Cisco switches always have VLAN 1 as the default VLAN, which is needed for many protocol communication between switches like spanning-tree protocol for instance.
You can't change or even delete the default VLAN, it is mandatory.
The native VLAN is the only VLAN which is not tagged in a trunk, in other words, native VLAN frames are transmitted unchanged.
Per default the native VLAN is VLAN 1 but you can change that:
#show interface Fa0/8 trunk
Port        Mode             Encapsulation  Status        Native vlan
Fa0/8       on               802.1q         other         1
(config-if)#switchport trunk native vlan 2
(config-if)#do show interface f0/8 trunk
Fa0/8       on               802.1q         other         2
The default VLAN is still VLAN 1.
#show vlan id 1
VLAN Name Status    Ports
1    default active    Fa0/8, Gi0/1
Rolf
Sandeep Choudhary Thu, 01/10/2013 - 04:47
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
HI Pradeep,
This has already been discussed amny times:
As for answering the initial question, let's make thing simple:
  • first we'll speak about the native VLAN in terms of data frames and not management frames such as CDP,STP,VTP
  • second,  the ONLY difference between a regular VLAN and the native VLAN is that  frames from/to the native VLAN are carried untagged; this is it.
Let's get into some details now:
  • the  IEEE 802.1q TRUNKING encapsulation standard says the NATIVE VLAN  represents traffic sent and received on an interface running 802.1q    encapsulation that does not have a tag.  So altough the NATIVE VLAN  exists also on access ports, its role is relevenat only on trunk ports.
  • here  is the thing: you have 2 switches connected via a trunk port; you  create VLAN 2 on both switches; on one end of the trunk you modify the  NATIVE VLAN to be VLAN2;what will happen, just a short description?; if  the first switch (with NATIVE VLAN 1 on the trunk) receives a frame from  VLAN1 and decides it needs to send the frame on the trunk port, it will  see that the frame was issued from VLAN1 which is the NATIVE VLAN on  the trunk port it will send the frame out the trunk port UNTAGGED. Now  when switch 2 receives the frame, it sees it is untagged and it will  associate the frme with its NATIVE VLAN which is VLAN2.
  • the  NATIVE VLAN can be modified on a per-port basis or it can be "disabled",  emaning you can configure some higher-end switches to tag all frames,  so there is not NATIVE VLAN.
  • with the CDP message saying "native  VLAN mismatch" the problem is not the error messasge but the thing that  you couls have L2 loops in the network or frames hopping between VLANs  directly at L2, without a L3 device.
The error message can be seen in multiple situations:
  • CDP version mismatch; CDP version 2 carries NATIVE VLAN information while CDP version 1 does not
  • trunk with mismatched NATIVE VLANs-----my example from above
  • both ends are configured as access but on different VLANs
  • one end is configured as access on VLAN x and the other end is configured as trunk with a NATIVE VLAN different than VLAN x.
please rate if it helps.
