Not able to get DHCP IP via 2504 WLAN Controller
Answered Question
Jan 8th, 2013
I have a Cisco Wlan Controller 2504 with 1042N AP (3-nos) every thing was working fine from past 2 months. Now i am getting a issue with clients which are connected to the wireless AP, they are not able to get an dhcp IP address from the 2960 Switch (DHCP Server). The clients are getting IP address as 0.0.0.0.
This is My Configuration:
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... WLAN
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.0.7
Last Reset....................................... Power on reset
System Up Time................................... 0 days 2 hrs 23 mins 22 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
                                                         Strong Password Check Features:
         case-check ...........Enabled
         consecutive-check ....Enabled
         default-check .......Enabled
         username-check ......Enabled
Press Enter to continue or <ctrl-z> to abort
Network Information
RF-Network Name............................. MEC
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Multicast   Address : 0.0.0.0
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Please Help !!!
Correct Answer by kcnajaf@25070 about 1 year 3 months ago
Use only Key Index 1.
Try creating an new SSID or may be make this SSID itself for testing with open authetication (Security None) and verify if the DHCP works.
Najaf
Average Rating: 5 (2 ratings)
Stephen Rodriguez Tue, 01/08/2013 - 07:31
Ok, so:
1.) is the scope exhausted on the 2960?
2.) what has changed recently?
3.) is dhcp proxy enabled or disabled?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
amankhang Tue, 01/08/2013 - 08:23
-No Its working fine, the pc's which are connected to the switch they are able to get DHCP IP.
-Nothing has changed.
-i checked it in the WLAN its enabled in it (If u are asking to check in WLAN)
Please still dind got any thing to get it working...
Stephen Rodriguez Tue, 01/08/2013 - 08:42
Proxy would either be Controller > Advanced or show dhcp proxy.
So you have only the one WLAN/interface?
HTH,
Steve
Scott Fella Tue, 01/08/2013 - 08:35
You try to delete the DHCP scope and add it back? The switch might be the issue. I have seen it before.
amankhang Tue, 01/08/2013 - 20:22
Tried deleting the DHCP scope on the switch and checked out still the issue is same..
kcnajaf@25070 Tue, 01/08/2013 - 21:33
Hi Amanulla,
Hope your WLC is configured as Trunk Interface, Please ensure that DHCP VLAN is allowed on the Trunk Links to the WLC and on all the path between WLC and DHCP switch.Also hope you dont have any interface which is configured on WLC with 0.0.0.0 address.
Najaf
Please rate when applicable or helpful !!!
amankhang Tue, 01/08/2013 - 21:36
yes it is a Trunking between the WLAN interface and to the Switch were it is connected...
I had removed the DHCP cope from the switch and configured on the router...
And rebooted the WLAN controller and NOW ! i am not getting the wifi SSID.
Please help on this !!!
kcnajaf@25070 Tue, 01/08/2013 - 21:39
Sorry,
You mean you are not able to view SSID on the wireless device? Is the SSID broadcasted? Can you get the configuration from WLC please?
Najaf
amankhang Tue, 01/08/2013 - 21:47
sorry, checked the broadcast SSID was uncheck and found the SSID.
But still not able to get the DHCP Ip address for the wifi clients
amankhang Tue, 01/08/2013 - 21:51
How to set the DHCP Server Ip address in the WLAN controller.
If i check that show dhcp proxy status i can see that the dhcp server is having the Ip address of the switch which was configured previously. but now the DHCP scope is on router and how can i change it to that ?
amankhang Tue, 01/08/2013 - 22:14
Changed to the correct DHCP IP address and rebooted the Controller also..
But still clients are not getting the DHCP IP address.. froan  the router..
Sholud the DHCP proxy should be enabled or disabled on the WLAN controller, if i am using external DHCP Server..
or
Can i enable DHCP pool in the WLAN only for the Clients who connect to the wifi..  from the IP address which are not in the router DHCP pool (Excluded Ip address).. ?
amankhang Tue, 01/08/2013 - 22:28
i get the following when i do sho dhcp stats
DHCP Server IP Address:.......................... 192.168.0.1
  DHCP DISCOVER Count:........................... 48
  DHCP REQUEST Count:............................ 0
  DHCP INFORM Count:............................. 0
  DHCP DECLINE Count:............................ 0
  DHCP RELEASE Count:............................ 0
  DHCP REPLY Count:.............................. 0
  DHCP OFFER Count:.............................. 48
  DHCP ACK Count:................................ 0
  DHCP NAK Count:................................ 0
  Tx Fails:...................................... 0
  Last Rx Time:.................................. 34 seconds ago
  Last Tx Time:.................................. 34 seconds ago
Scott Fella Tue, 01/08/2013 - 22:36
Can you post your show run-config
amankhang Tue, 01/08/2013 - 22:53
find the Show run-config
(Cisco Controller) >show run-config
Press Enter to continue...
System Inventory
NAME: "Chassis"    , DESCR: "Cisco 2500 Series Wireless LAN Controller"
PID: AIR-CT2504-K9,  VID: V01,  SN: PSJ1623093K
Burned-in MAC Address............................ F4:7F:35:B7:70:20
Maximum number of APs supported.................. 5
Press Enter to continue or to abort
System Information
System Name...................................... IMEC-WLAN
Last Reset....................................... Software reset
System Up Time................................... 0 days 0 hrs 10 mins 25 secs
--More or (q)uit current module or to abort
Next Boot License Type........................... Permanent
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +26 C
External Temperature............................. +31 C
Fan Status....................................... 4300 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 3
AP Bundle Information
Primary AP ImageSize
ap3g15792
ap8015192
ap8025232
c11003084
c11304964
c11404992
c12003364
c12404812
c12505504
c13103136
c15206404
c32014324
c602i3716
Secondary AP ImageSize
ap3g15792
ap8015192
ap8025232
c11003084
c11304964
c11404992
c12003364
c12404812
c12505504
c13103136
c15206404
c32014324
c602i3716
Network Information
RF-Network Name............................. IMEC
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Web Auth Proxy Redirect  ................... Disable
Fast SSID Change ........................... Disabled
IP/MAC Addr Binding Check .................. Enabled
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A
2  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
3  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
4  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
AP Summary
Number of APs.................................... 3
Global AP User Name.............................. Not Configured
Global AP Dot1x User Name........................ Not Configured
AP Name             Slots  AP Model              Ethernet MAC       Location          Port  Country  Priority
IMEC-AP2             2     AIR-LAP1042N-N-K9     ac:f2:c5:f3:ea:32  default location  1        US       1
IMEC-AP3             2     AIR-LAP1042N-N-K9     ac:f2:c5:f2:78:c2  default location  1        US       1
IMEC-AP1             2     AIR-LAP1042N-N-K9     ac:f2:c5:f3:ee:16  default location  1        US       1
AP Tcp-Mss-Adjust Info
AP Name              TCP State  MSS Size
IMEC-AP2             disabled   -
IMEC-AP3             disabled   -
IMEC-AP1             disabled   -
AP Location
Total Number of AP Groups........................ 0
Site Name........................................ default-group
Site Description.................................
WLAN ID          Interface          Network Admission Control          Radio Policy
1               management           Disabled                          None
AP Config
Cisco AP Identifier.............................. 0
Cisco AP Name.................................... IMEC-AP2
Country code..................................... US  - United States
Regulatory Domain allowed by Country............. 802.11bg:-A     802.11a:-A
AP Country code.................................. US  - United States
AP Regulatory Domain............................. -A
Switch Port Number .............................. 1
MAC Address...................................... ac:f2:c5:f3:ea:32
IP Address Configuration......................... Static IP assigned
IP Address....................................... 192.168.0.9
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. 192.168.0.1
Domain...........................................
Name Server......................................
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Disabled
Ssh State........................................ Disabled
Cisco AP Location................................ default location
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................
Primary Cisco Switch IP Address.................. Not Configured
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... kern
S/W  Version .................................... 7.0.220.0
Boot  Version ................................... 12.4.23.6
Mini IOS Version ................................ 7.3.1.73
Stats Reporting Period .......................... 180
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
AP Model......................................... AIR-LAP1042N-N-K9
AP Image......................................... C1040-K9W8-M
IOS Version...................................... 12.4(23c)JA3
Reset Button..................................... Enabled
AP Serial Number................................. FGL1646S52Q
AP Certificate Type.............................. Manufacture Installed
AP User Mode..................................... AUTOMATIC
AP User Name..................................... Not Configured
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 0 days, 01 h 07 m 47 s
AP LWAPP Up Time................................. 0 days, 00 h 09 m 27 s
Join Date and Time............................... Wed Jan  9 12:12:27 2013
Join Taken Time.................................. 0 days, 00 h 01 m 33 s
Attributes for Slot  0
    Radio Type................................... RADIO_TYPE_80211n-2.4
    Administrative State ........................ ADMIN_ENABLED
    Operation State ............................. UP
    Radio Role .................................. ACCESS
    CellId ...................................... 0
    Station Configuration
      Configuration ............................. AUTOMATIC
      Number Of WLANs ........................... 1
      Medium Occupancy Limit .................... 100
      CFP Period ................................ 4
      CFP MaxDuration ........................... 60
      BSSID ..................................... cc:d5:39:d0:bf:80
      Operation Rate Set
        1000 Kilo Bits........................... MANDATORY
        2000 Kilo Bits........................... MANDATORY
        5500 Kilo Bits........................... MANDATORY
        11000 Kilo Bits.......................... MANDATORY
        6000 Kilo Bits........................... SUPPORTED
        9000 Kilo Bits........................... SUPPORTED
        12000 Kilo Bits.......................... SUPPORTED
        18000 Kilo Bits.......................... SUPPORTED
        24000 Kilo Bits.......................... SUPPORTED
        36000 Kilo Bits.......................... SUPPORTED
        48000 Kilo Bits.......................... SUPPORTED
        54000 Kilo Bits.......................... SUPPORTED
      MCS Set
        MCS 0.................................... SUPPORTED
        MCS 1.................................... SUPPORTED
        MCS 2.................................... SUPPORTED
        MCS 3.................................... SUPPORTED
        MCS 4.................................... SUPPORTED
        MCS 5.................................... SUPPORTED
        MCS 6.................................... SUPPORTED
        MCS 7.................................... SUPPORTED
        MCS 8.................................... SUPPORTED
        MCS 9.................................... SUPPORTED
        MCS 10................................... SUPPORTED
        MCS 11................................... SUPPORTED
        MCS 12................................... SUPPORTED
        MCS 13................................... SUPPORTED
        MCS 14................................... SUPPORTED
        MCS 15................................... SUPPORTED
      Beacon Period ............................. 100
      Fragmentation Threshold ................... 2346
      Multi Domain Capability Implemented ....... TRUE
      Multi Domain Capability Enabled ........... TRUE
      Country String ............................ US
      First Chan Num ............................ 1
      Number Of Channels ........................ 11
    MAC Operation Parameters
      Packet Retry Limit ........................ 64
    Tx Power
      Num Of Supported Power Levels ............. 8
      Tx Power Level 1 .......................... 20 dBm
      Tx Power Level 2 .......................... 17 dBm
      Tx Power Level 3 .......................... 14 dBm
      Tx Power Level 4 .......................... 11 dBm
      Tx Power Level 5 .......................... 8 dBm
      Tx Power Level 6 .......................... 5 dBm
      Tx Power Level 7 .......................... 2 dBm
      Tx Power Level 8 .......................... -1 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 1
    Phy OFDM parameters
      Current Channel ........................... 1
      Extension Channel ......................... NONE
      Channel Width.............................. 20 Mhz
      Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11
      TI Threshold .............................. -50
      Legacy Tx Beamforming Configuration ....... AUTOMATIC
      Legacy Tx Beamforming ..................... DISABLED
      Antenna Type............................... INTERNAL_ANTENNA
      Internal Antenna Gain (in .5 dBi units).... 8
      Diversity.................................. DIVERSITY_ENABLED
      802.11n Antennas
         A....................................... ENABLED
         B....................................... ENABLED
         C....................................... DISABLED
    Performance Profile Parameters
      Interference threshold..................... 10 %
      Noise threshold............................  -70 dBm
      RF utilization threshold................... 80 %
      Data-rate threshold........................ 1000000 bps
      Client threshold........................... 12 clients
      Coverage SNR threshold..................... 12 dB
      Coverage exception level................... 25 %
      Client minimum exception level............. 3 clients
    Rogue Containment Information
    Containment Count............................ 0
    CleanAir Management Information
        CleanAir Capable......................... No
AP Regulatory Domain............................. -N
Attributes for Slot  1
    Regulatory Domain check for this slot has Failed. This slot will not be operational
Cisco AP Identifier.............................. 1
Cisco AP Name.................................... IMEC-AP3
MAC Address...................................... ac:f2:c5:f2:78:c2
IP Address....................................... 192.168.0.10
AP Serial Number................................. FGL1646S52P
AP Up Time....................................... 0 days, 01 h 07 m 56 s
AP LWAPP Up Time................................. 0 days, 00 h 09 m 32 s
Join Date and Time............................... Wed Jan  9 12:12:31 2013
Join Taken Time.................................. 0 days, 00 h 01 m 40 s
      BSSID ..................................... cc:d5:39:d0:c8:70
      Operation Rate Set
      MCS Set
(Cisco Controller) >logout
Scott Fella Tue, 01/08/2013 - 23:01
I don't see your WLAN config nor your interface config
Scott Fella Tue, 01/08/2013 - 23:03
Can you do config paging disable then issue the show run-config no-ap and save that to a text file and attach it. Don't paste it into the thread.
amankhang Tue, 01/08/2013 - 23:09
find this
System Inventory
System Information
System Up Time................................... 0 days 0 hrs 9 mins 21 secs
External Temperature............................. +32 C
Number of Active Clients......................... 2
ap3g15792
ap8015192
ap8025232
c11003084
c11304964
c11404992
c12003364
c12404812
c12505504
c13103136
c15206404
c32014324
c602i3716
ap3g15792
ap8015192
ap8025232
c11003084
c11304964
c11404992
c12003364
c12404812
c12505504
c13103136
c15206404
c32014324
c602i3716
Network Information
Port Summary
AP Summary
IMEC-AP3             disabled   -
IMEC-AP2             disabled   -
IMEC-AP1             disabled   -
AP Location
AP Config
AP Up Time....................................... 0 days, 00 h 04 m 10 s
AP LWAPP Up Time................................. 0 days, 00 h 03 m 14 s
Join Date and Time............................... Wed Jan  9 12:31:35 2013
Join Taken Time.................................. 0 days, 00 h 00 m 55 s
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      Current Channel ........................... 11
      802.11n Antennas
AP Up Time....................................... 0 days, 00 h 02 m 56 s
AP LWAPP Up Time................................. 0 days, 00 h 02 m 00 s
Join Date and Time............................... Wed Jan  9 12:32:50 2013
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
Cisco AP Identifier.............................. 2
Cisco AP Name.................................... IMEC-AP1
MAC Address...................................... ac:f2:c5:f3:ee:16
IP Address....................................... 192.168.0.8
AP Serial Number................................. FGL1646S52M
AP Up Time....................................... 0 days, 00 h 01 m 59 s
AP LWAPP Up Time................................. 0 days, 00 h 01 m 03 s
Join Date and Time............................... Wed Jan  9 12:33:48 2013
      BSSID ..................................... cc:d5:39:d1:0c:20
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      Current Channel ........................... 6
      802.11n Antennas
AP Airewave Director Configuration
AP Name.......................................... IMEC-AP3
  Slot ID........................................ 0
  Radio Type..................................... RADIO_TYPE_80211b/g
  Sub-band Type.................................. All
  Noise Information
    Noise Profile................................ PASSED
    Channel 1....................................  -90 dBm
    Channel 2....................................  -93 dBm
    Channel 3....................................  -93 dBm
    Channel 4....................................  -89 dBm
    Channel 5....................................  -89 dBm
    Channel 6....................................  -91 dBm
    Channel 7....................................  -92 dBm
    Channel 8....................................  -93 dBm
    Channel 9....................................  -92 dBm
    Channel 10...................................  -93 dBm
    Channel 11...................................  -88 dBm
  Interference Information
    Interference Profile......................... PASSED
    Channel 1....................................  -81 dBm @  1 % busy
    Channel 2.................................... -128 dBm @  0 % busy
    Channel 3.................................... -128 dBm @  0 % busy
    Channel 4.................................... -128 dBm @  0 % busy
    Channel 5.................................... -128 dBm @  0 % busy
    Channel 6.................................... -128 dBm @  0 % busy
    Channel 7.................................... -128 dBm @  0 % busy
    Channel 8....................................  -75 dBm @  1 % busy
    Channel 9.................................... -128 dBm @  0 % busy
    Channel 10................................... -128 dBm @  0 % busy
    Channel 11................................... -128 dBm @  0 % busy
  Load Information
    Load Profile................................. PASSED
    Receive Utilization.......................... 0 %
    Transmit Utilization......................... 1 %
    Channel Utilization.......................... 7 %
    Attached Clients............................. 1 clients
  Coverage Information
    Coverage Profile............................. PASSED
    Failed Clients............................... 0 clients
  Client Signal Strengths
    RSSI -100 dbm................................ 0 clients
    RSSI  -92 dbm................................ 0 clients
    RSSI  -84 dbm................................ 0 clients
    RSSI  -76 dbm................................ 0 clients
    RSSI  -68 dbm................................ 1 clients
    RSSI  -60 dbm................................ 0 clients
    RSSI  -52 dbm................................ 0 clients
  Client Signal To Noise Ratios
    SNR    0 dB.................................. 0 clients
    SNR    5 dB.................................. 0 clients
    SNR   10 dB.................................. 0 clients
    SNR   15 dB.................................. 0 clients
    SNR   20 dB.................................. 0 clients
    SNR   25 dB.................................. 1 clients
    SNR   30 dB.................................. 0 clients
    SNR   35 dB.................................. 0 clients
    SNR   40 dB.................................. 0 clients
    SNR   45 dB.................................. 0 clients
  Nearby APs
    AP cc:d5:39:d0:bf:80 slot 0..................  -62 dBm on   1 (192.168.0.7)
  Radar Information
  Channel Assignment Information
    Current Channel Average Energy............... unknown
    Previous Channel Average Energy.............. unknown
    Channel Change Count......................... 0
    Last Channel Change Time..................... Wed Jan  9 12:31:35 2013
    Recommended Best Channel..................... 11
  RF Parameter Recommendations
    Power Level.................................. 1
    RTS/CTS Threshold............................ 2347
    Fragmentation Threshold...................... 2346
    Antenna Pattern.............................. 0
  Persistent Interference Devices
  Class Type                 Channel  DC (%%)  RSSI (dBm)  Last Update Time
  All third party trademarks are the property of their respective owners.
  Slot ID........................................ 1
  Radio Type..................................... RADIO_TYPE_80211a
  Noise Information
    Rogue Histogram (20/40_ABOVE/40_BELOW)
  Load Information
    Transmit Utilization......................... 0 %
    Channel Utilization.......................... 0 %
    Attached Clients............................. 0 clients
    RSSI  -68 dbm................................ 0 clients
    SNR   25 dB.................................. 0 clients
  Nearby APs
  Radar Information
    Power Level.................................. 0
    RTS/CTS Threshold............................ 0
    Fragmentation Threshold...................... 0
AP Name.......................................... IMEC-AP2
  Noise Information
  Load Information
    Channel Utilization.......................... 4 %
    RSSI  -60 dbm................................ 1 clients
    SNR   30 dB.................................. 1 clients
  Nearby APs
    AP cc:d5:39:d0:c8:70 slot 0..................  -57 dBm on  11 (192.168.0.7)
  Radar Information
    Last Channel Change Time..................... Wed Jan  9 12:32:50 2013
  Noise Information
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... IMEC-AP1
  Noise Information
  Load Information
    Channel Utilization.......................... 9 %
  Nearby APs
  Radar Information
    Last Channel Change Time..................... Wed Jan  9 12:33:48 2013
    Recommended Best Channel..................... 6
  Noise Information
  Load Information
  Nearby APs
  Radar Information
802.11a Configuration
802.11a Network.................................. Enabled
11nSupport....................................... Enabled
      802.11a Low Band........................... Enabled
      802.11a Mid Band........................... Enabled
      802.11a High Band.......................... Enabled
802.11a Operational Rates
    802.11a 6M Rate.............................. Mandatory
    802.11a 9M Rate.............................. Supported
    802.11a 12M Rate............................. Mandatory
    802.11a 18M Rate............................. Supported
    802.11a 24M Rate............................. Mandatory
    802.11a 36M Rate............................. Supported
    802.11a 48M Rate............................. Supported
    802.11a 54M Rate............................. Supported
802.11n MCS Settings:
    MCS 0........................................ Supported
    MCS 1........................................ Supported
    MCS 2........................................ Supported
    MCS 3........................................ Supported
    MCS 4........................................ Supported
    MCS 5........................................ Supported
    MCS 6........................................ Supported
    MCS 7........................................ Supported
    MCS 8........................................ Supported
    MCS 9........................................ Supported
    MCS 10....................................... Supported
    MCS 11....................................... Supported
    MCS 12....................................... Supported
    MCS 13....................................... Supported
    MCS 14....................................... Supported
    MCS 15....................................... Supported
802.11n Status:
    A-MPDU Tx:
        Priority 0............................... Enabled
        Priority 1............................... Disabled
        Priority 2............................... Disabled
        Priority 3............................... Disabled
        Priority 4............................... Enabled
        Priority 5............................... Enabled
        Priority 6............................... Disabled
        Priority 7............................... Disabled
    A-MSDU Tx:
        Priority 1............................... Enabled
        Priority 2............................... Enabled
        Priority 3............................... Enabled
    Rifs Rx ..................................... Enabled
    Guard Interval .............................. Any
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 0
DTPC  Status..................................... Enabled
Fragmentation Threshold.......................... 2346
TI Threshold..................................... -50
Legacy Tx Beamforming setting.................... Disabled
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
World Mode....................................... Enabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
Call Admission Control (CAC) configuration
Voice AC:
   Voice AC - Admission control (ACM)............ Disabled
   Voice Stream-Size............................. 84000
   Voice Max-Streams............................. 2
   Voice max RF bandwidth........................ 75
   Voice reserved roaming bandwidth.............. 6
   Voice CAC Method ............................. Load-Based
   Voice tspec inactivity timeout................ Disabled
CAC SIP-Voice configuration
   SIP based CAC ................................ Disabled
   SIP Codec Type ............................... CODEC_TYPE_G711
   SIP call bandwidth ........................... 64
   SIP call bandwith sample-size ................ 20
Video AC:
   Video AC - Admission control (ACM)............ Disabled
   Video max RF bandwidth........................ Infinite
   Video reserved roaming bandwidth.............. 0
   Best-effort AC - Admission control (ACM)...... Disabled
   Background AC - Admission control (ACM)....... Disabled
802.11a Advanced Configuration
AP Name                          MAC Address        Admin State  Operation State Channel    TxPower
IMEC-AP3                         cc:d5:39:d0:c8:70  ENABLED      DOWN            165*         1(*)
IMEC-AP2                         cc:d5:39:d0:bf:80  ENABLED      DOWN            165*         1(*)
IMEC-AP1                         cc:d5:39:d1:0c:20  ENABLED      DOWN            165*         1(*)
802.11a Airewave Director Configuration
RF Event and Performance Logging
  Channel Update Logging......................... Off
  Coverage Profile Logging....................... Off
  Foreign Profile Logging........................ Off
  Load Profile Logging........................... Off
  Noise Profile Logging.......................... Off
  Performance Profile Logging.................... Off
  TxPower Update Logging......................... Off
Default 802.11a AP performance profiles
  802.11a Global Interference threshold.......... 10 %
  802.11a Global noise threshold................. -70 dBm
  802.11a Global RF utilization threshold........ 80 %
  802.11a Global throughput threshold............ 1000000 bps
  802.11a Global clients threshold............... 12 clients
Default 802.11a AP monitoring
  802.11a Monitor Mode........................... enable
  802.11a Monitor Mode for Mesh AP Backhaul...... disable
  802.11a Monitor Channels....................... Country channels
  802.11a RRM Neighbor Discover Type............. Transparent
  802.11a AP Coverage Interval................... 180 seconds
  802.11a AP Load Interval....................... 60 seconds
  802.11a AP Noise Interval...................... 180 seconds
  802.11a AP Signal Strength Interval............ 60 seconds
Automatic Transmit Power Assignment
  Transmit Power Assignment Mode................. AUTO
  Transmit Power Update Interval................. 600 seconds
  Transmit Power Threshold....................... -70 dBm
  Transmit Power Neighbor Count.................. 3 APs
  Min Transmit Power............................. -10 dBm
  Max Transmit Power............................. 30 dBm
  Transmit Power Update Contribution............. SNI..
  Transmit Power Assignment Leader............... IMEC-WLAN (192.168.0.7)
  Last Run....................................... 533 seconds ago
Coverage Hole Detection
  802.11a Coverage Hole Detection Mode........... Enabled
  802.11a Coverage Voice Packet Count............ 100 packets
  802.11a Coverage Voice Packet Percentage....... 50%
  802.11a Coverage Voice RSSI Threshold.......... -80 dBm
  802.11a Coverage Data Packet Count............. 50 packets
  802.11a Coverage Data Packet Percentage........ 50%
  802.11a Coverage Data RSSI Threshold........... -80 dBm
  802.11a Global coverage exception level........ 25 %
  802.11a Global client minimum exception lev.... 3 clients
Automatic Channel Assignment
  Channel Assignment Mode........................ AUTO
  Channel Update Interval........................ 600 seconds [startup]
  Anchor time (Hour of the day).................. 0
  Channel Update Contribution.................... SNI..
  CleanAir Event-driven RRM option............... Disabled
  CleanAir Event-driven RRM sensitivity.......... Medium
  Channel Assignment Leader...................... IMEC-WLAN (192.168.0.7)
  DCA Sensitivity Level.......................... STARTUP (5 dB)
  DCA 802.11n Channel Width...................... 20 MHz
  DCA Minimum Energy Limit....................... -95 dBm
  Channel Energy Levels
    Minimum...................................... unknown
    Average...................................... unknown
    Maximum...................................... unknown
  Channel Dwell Times
  802.11a 5 GHz Auto-RF Channel List
    Allowed Channel List......................... 36,40,44,48,52,56,60,64,149,
                                                  153,157,161
    Unused Channel List.......................... 100,104,108,112,116,132,136,
                                                  140,165
  802.11a 4.9 GHz Auto-RF Channel List
    Unused Channel List.......................... 1,2,3,4,5,6,7,8,9,10,11,12,
                                                  13,14,15,16,17,18,19,20,21,
                                                  22,23,24,25,26
  DCA Outdoor AP option.......................... Disabled
Radio RF Grouping
  802.11a Group Mode............................. AUTO
  802.11a Group Update Interval.................. 600 seconds
  802.11a Group Leader........................... IMEC-WLAN (192.168.0.7)
    802.11a Group Member......................... IMEC-WLAN (192.168.0.7)
  802.11a Last Run............................... 533 seconds ago
802.11a CleanAir Configuration
Clean Air Solution............................... Disabled
Air Quality Settings:
    Air Quality Reporting........................ Enabled
    Air Quality Reporting Period (min)........... 15
    Air Quality Alarms........................... Enabled
    Air Quality Alarm Threshold.................. 35
Interference Device Settings:
    Interference Device Reporting................ Enabled
    Interference Device Types:
        TDD Transmitter.......................... Enabled
        Jammer................................... Enabled
        Continuous Transmitter................... Enabled
        DECT-like Phone.......................... Enabled
        Video Camera............................. Enabled
        WiFi Inverted............................ Enabled
        WiFi Invalid Channel..................... Enabled
        SuperAG.................................. Enabled
        Canopy................................... Enabled
        WiMax Mobile............................. Enabled
        WiMax Fixed.............................. Enabled
    Interference Device Alarms................... Enabled
    Interference Device Types Triggering Alarms:
        TDD Transmitter.......................... Disabled
        Continuous Transmitter................... Disabled
        DECT-like Phone.......................... Disabled
        Video Camera............................. Disabled
        SuperAG.................................. Disabled
        Canopy................................... Disabled
        WiMax Mobile............................. Disabled
        WiMax Fixed.............................. Disabled
Additional Clean Air Settings:
    CleanAir Event-driven RRM State.............. Disabled
    CleanAir Driven RRM Sensitivity.............. Medium
    CleanAir Persistent Devices state............ Disabled
802.11a CleanAir AirQuality Summary
AQ = Air Quality
DFS = Dynamic Frequency Selection
AP Name            Channel Avg AQ Min AQ Interferers DFS
802.11b Configuration
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
802.11b/g Operational Rates
    802.11b/g 1M Rate............................ Mandatory
    802.11b/g 2M Rate............................ Mandatory
    802.11b/g 5.5M Rate.......................... Mandatory
    802.11b/g 11M Rate........................... Mandatory
    802.11g 6M Rate.............................. Supported
    802.11g 9M Rate.............................. Supported
    802.11g 12M Rate............................. Supported
    802.11g 18M Rate............................. Supported
    802.11g 24M Rate............................. Supported
    802.11g 36M Rate............................. Supported
    802.11g 48M Rate............................. Supported
    802.11g 54M Rate............................. Supported
802.11n Status:
    A-MPDU Tx:
    A-MSDU Tx:
CF Pollable mode................................. Disabled
Default Channel.................................. 1
Call Admission Limit  ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
PBCC mandatory................................... Disabled
RTS Threshold.................................... 2347
Short Preamble mandatory......................... Enabled
Short Retry Limit................................ 7
Faster Carrier Tracking Loop..................... Disabled
   Voice CAC Method.............................. Load-Based
   SIP call bandwidth: .......................... 64
   SIP call bandwidth sample-size ............... 20
802.11b Advanced Configuration
IMEC-AP3                         cc:d5:39:d0:c8:70  ENABLED      UP              11*          1(*)
IMEC-AP2                         cc:d5:39:d0:bf:80  ENABLED      UP              1*           1(*)
IMEC-AP1                         cc:d5:39:d1:0c:20  ENABLED      UP              6*           1(*)
802.11b Airewave Director Configuration
  Transmit Power Update Logging.................. Off
Default 802.11b AP performance profiles
  802.11b Global Interference threshold.......... 10 %
  802.11b Global noise threshold................. -70 dBm
  802.11b Global RF utilization threshold........ 80 %
  802.11b Global throughput threshold............ 1000000 bps
  802.11b Global clients threshold............... 12 clients
Default 802.11b AP monitoring
  802.11b Monitor Mode........................... enable
  802.11b Monitor Channels....................... Country channels
  802.11b RRM Neighbor Discovery Type............ Transparent
  802.11b AP Coverage Interval................... 180 seconds
  802.11b AP Load Interval....................... 60 seconds
  802.11b AP Noise Interval...................... 180 seconds
  802.11b AP Signal Strength Interval............ 60 seconds
  Last Run....................................... 536 seconds ago
  802.11b Coverage Hole Detection Mode........... Enabled
  802.11b Coverage Voice Packet Count............ 100 packets
  802.11b Coverage Voice Packet Percentage....... 50%
  802.11b Coverage Voice RSSI Threshold.......... -80 dBm
  802.11b Coverage Data Packet Count............. 50 packets
  802.11b Coverage Data Packet Percentage........ 50%
  802.11b Coverage Data RSSI Threshold........... -80 dBm
  802.11b Global coverage exception level........ 25 %
  802.11b Global client minimum exception lev.... 3 clients
  DCA Sensitivity Level: ...................... STARTUP (5 dB)
  Channel Dwell Times
    Minimum...................................... 0 days, 00 h 01 m 14 s
    Average...................................... 0 days, 00 h 02 m 17 s
    Maximum...................................... 0 days, 00 h 03 m 27 s
  802.11b Auto-RF Allowed Channel List........... 1,6,11
  Auto-RF Unused Channel List.................... 2,3,4,5,7,8,9,10
Radio RF Grouping
  802.11b Group Mode............................. AUTO
  802.11b Group Update Interval.................. 600 seconds
  802.11b Group Leader........................... IMEC-WLAN (192.168.0.7)
    802.11b Group Member......................... IMEC-WLAN (192.168.0.7)
  802.11b Last Run............................... 536 seconds ago
        Bluetooth Link........................... Enabled
        Microwave Oven........................... Enabled
        802.11 FH................................ Enabled
        Bluetooth Discovery...................... Enabled
        802.15.4................................. Enabled
        Microsoft Device......................... Enabled
        Bluetooth Link........................... Disabled
        Microwave Oven........................... Disabled
        802.11 FH................................ Disabled
        Bluetooth Discovery...................... Disabled
        802.15.4................................. Disabled
        Microsoft Device......................... Disabled
AQ = Air Quality
Mobility Configuration
Symmetric Mobility Tunneling (current) .......... Enabled
Symmetric Mobility Tunneling (after reboot) ..... Enabled
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... IMEC
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x9344
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 1
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address        IP Address       Group Name                        Multicast IP     Status
f4:7f:35:b7:70:20  192.168.0.7      IMEC                              0.0.0.0          Up
Mobility Foreign Map Configuration
WLAN ID     Foreign Mac Address     Interface
Probe request filtering..........................  Enabled
Probes fwd to controller per client per radio....  2
Probe request rate-limiting interval.............  500 msec
Aggregate Probe request interval.................  500 msec
EAP-Identity-Request Timeout (seconds)........... 30
EAP-Identity-Request Max Retries................. 2
EAP Key-Index for Dynamic WEP.................... 0
EAP Max-Login Ignore Identity Response........... enable
EAP-Request Timeout (seconds).................... 30
EAP-Request Max Retries.......................... 2
EAPOL-Key Timeout (milliseconds)................. 1000
EAPOL-Key Max Retries............................ 2
EAP-Broadcast Key Interval....................... 3600
Fastpath Packet Capture.......................... disable
Fastpath Fast Cache Control...................... enable
Fastpath Fast Testmode........................... 0x0
dot11-padding.................................... Disabled
Location Configuration
RFID Tag data Collection......................... Enabled
RFID  timeout.................................... 1200 seconds
RFID mobility.................................... Oui:00:14:7e : Vendor:pango  State:Disabled
Interface Configuration
Interface Name................................... management
MAC Address...................................... f4:7f:35:b7:70:20
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.0.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 192.168.0.1
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Disabled
Interface Name................................... virtual
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ Disabled
AP Manager....................................... No
Interface Group Configuration
WLAN Configuration
WLAN Identifier.................................. 1
Profile Name..................................... IMEC-INDIA
Network Name (SSID).............................. IMEC-INDIA
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Enabled
Key Index:...................................... 2
Encryption:..................................... 104-bit WEP
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
ACL Configuration
CPU ACL Configuration
CPU Acl Name................................ NOT CONFIGURED
Wireless Traffic............................ Disabled
Wired Traffic............................... Disabled
RADIUS Configuration
Vendor Id Backward Compatibility................. Disabled
Call Station Id Case............................. lower
Call Station Id Type............................. IP Address
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Fallback Test:
    Test Mode.................................... Off
    Probe User Name.............................. cisco-probe
    Interval (in seconds)........................ 300
MAC Delimiter for Authentication Messages........ hyphen
MAC Delimiter for Accounting Messages............ hyphen
Authentication Servers
Idx  Type  Server Address    Port    State     Tout  RFC3576  IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
Accounting Servers
TACACS Configuration
Idx  Server Address    Port    State     Tout
Authorization Servers
Accounting Servers
LDAP Configuration
Local EAP Configuration
User credentials database search order:
    Primary ..................................... Local DB
Timer:
    Active timeout .............................. 300
Configured EAP profiles:
EAP Method configuration:
    EAP-FAST:
      Server key ................................
      TTL for the PAC ........................... 10
      Anonymous provision allowed ............... Yes
      Authority ID .............................. 436973636f0000000000000000000000
      Authority Information ..................... Cisco A-ID
HREAP Group Summary
HREAP Group Summary: Count: 0
Group Name                # Aps
HREAP Group Detail
Route  Info
Number of Routes................................. 0
Destination Network          Netmask               Gateway
Qos Queue Length Info
Platinum queue length............................ 100
Gold queue length................................  75
Silver queue length..............................  50
Bronze queue length..............................  25
Mac Filter Info
Authorization List
Authorize MIC APs against AAA ................... disabled
Authorize LSC APs against Auth-List ............. disabled
APs Allowed to Join
  AP with Manufacturing Installed Certificate.... yes
  AP with Self-Signed Certificate................ no
  AP with Locally Significant Certificate........ no
Load Balancing Info
Aggressive Load Balancing........................ per WLAN enabling
Aggressive Load Balancing Window................. 5 clients
Aggressive Load Balancing Denial Count........... 3
Statistics
Total Denied Count............................... 0 clients
Total Denial Sent................................ 0 messages
Exceeded Denial Max Limit Count.................. 0 times
None 5G Candidate Count.......................... 0 times
None 2.4G Candidate Count........................ 0 times
DHCP Info
No leases allocated.
DHCP Opt-82 RID Format:
DHCP Proxy Behaviour:enabled
  DHCP DISCOVER Count:........................... 24
  DHCP OFFER Count:.............................. 23
  Last Rx Time:.................................. 39 seconds ago
  Last Tx Time:.................................. 39 seconds ago
Exclusion List ConfigurationUnable to retrieve exclusion-list entry
CDP Configuration
cdp version v2
Country Channels Configuration
Configured Country............................. US  - United States
      KEY: * = Channel is legal in this country and may be configured manually.
           A = Channel is the Auto-RF default in this country.
           . = Channel is not legal in this country.
           C = Channel has been configured for use by Auto-RF.
           x = Channel is available to be configured for use by Auto-RF.
         (-,-) = (indoor, outdoor) regulatory doamin allowed by this country.
    802.11bg     :
    Channels     :                   1 1 1 1 1
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4
US (-A   ,-AB  ): A * * * * A * * * * A . . .
    802.11a      :                         1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    Channels     : 3 3 3 4 4 4 4 4 5 5 6 6 0 0 0 1 1 2 2 2 3 3 4 4 5 5 6 6
                 : 4 6 8 0 2 4 6 8 2 6 0 4 0 4 8 2 6 0 4 8 2 6 0 9 3 7 1 5
US (-A   ,-AB  ): . A . A . A . A A A A A * * * * * . . . * * * A A A A *
4.9GHz 802.11a  :
    Channels     :                   1 1 1 1 1 1 1 1 1 1 2 2 2 2 2 2 2
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
US (-A   ,-AB  ): * * * * * * * * * * * * * * * * * * * A * * * * * A
WPS Configuration Summary
Auto-Immune
  Auto-Immune.................................... Disabled
Client Exclusion Policy
  Excessive 802.11-association failures.......... Enabled
  Excessive 802.11-authentication failures....... Enabled
  Excessive 802.1x-authentication................ Enabled
  IP-theft....................................... Enabled
  Excessive Web authentication failure........... Enabled
Signature Policy
  Signature Processing........................... Enabled
Custom Web Configuration
Radius Authentication Method..................... PAP
Cisco Logo....................................... Enabled
CustomLogo....................................... None
Custom Title..................................... None
Custom Message................................... None
Custom Redirect URL.............................. None
Web Authentication Type.......................... Internal Default
External Web Authentication URL.................. None
Configuration Per Profile:
Core dump Configuration
Core Dump is disabled
Rogue AP Configuration
Rogue on wire Auto-Contain....................... Disabled
Rogue using our SSID Auto-Contain................ Disabled
Valid client on rogue AP Auto-Contain............ Disabled
Rogue AP timeout................................. 1200
Monitor Mode Report Interval..................... 10
MAC Address        Classification     # APs # Clients Last Heard
00:27:22:4e:0a:ac  Pending            1     0         Wed Jan  9 12:34:40 2013
00:e0:4c:00:57:48  Pending            1     0         Wed Jan  9 12:34:40 2013
04:4f:aa:33:08:38  Pending            1     0         Wed Jan  9 12:34:40 2013
Adhoc Rogue Configuration
Detect and report Ad-Hoc Networks................ Enabled
Auto-Contain Ad-Hoc Networks..................... Disabled
Client MAC Address  Adhoc BSSID         State              # APs   Last Heard
Rogue Client Configuration
Validate rogue clients against AAA............... Disabled
MAC Address        State              # APs Last Heard
Ignore List Configuration
MAC Address
Rogue Rule Configuration
Priority Rule Name               State    Type          Match Hit Count
Media-Stream Configuration
Multicast-direct State........................... disable
Allowed WLANs....................................
Stream Name   Start IP       End IP         Operation Status
URL..............................................
E-mail...........................................
Phone............................................
Note.............................................
State............................................ disable
2.4G Band Media-Stream Configuration
Multicast-direct................................. Enabled
Best Effort...................................... Disabled
Video Re-Direct.................................. Enabled
Max Allowed Streams Per Radio.................... Auto
Max Allowed Streams Per Client................... Auto
Max Video Bandwidth.............................. 0
Max Voice Bandwidth.............................. 75
Max Media Bandwidth.............................. 85
Min PHY Rate..................................... 6000
Max Retry Percentage............................. 80
5G Band Media-Stream Configuration
Number of Clients................................ 0
Client Mac         Stream Name  Stream Type  Radio WLAN  QoS    Status
(Cisco Controller) >?
kcnajaf@25070 Tue, 01/08/2013 - 23:19
Could you try modyting yiu configuration as below
DHCP Server...................................... Default (Change to 192.168.0.1)
DHCP Address Assignment Required................. Disabled (Change to Enable)
Najaf
shibivdev Wed, 01/09/2013 - 02:47
Hav you checked the Configuration of the Virtual Interface associated with SSID, because DHCP Server IP should be added in the interface, you can confirm that through GUI of the Controller
amankhang Wed, 01/09/2013 - 05:51
-Najaf
Not able to find the command or in the GUI to change the following parameters.. any idea on that
-shibivdev
i did'nt got similar to that in the interfaces but i have:
and
kcnajaf@25070 Wed, 01/09/2013 - 06:12
This will under WLANs-->Click on WLAN ID (Of the SSID which you want this change)-->Advance Tab --> DHCP
Hope this is the path as i have not worked on 2504 :-)
Najaf
amankhang Wed, 01/09/2013 - 06:32
made those changes:
before changes:
after changes:
I have a remote of it and gonna check it tomarrow morning
But tell me "every thing was working fine from past two months" the client used to get ip address and accesability.
how can it stop working with out any changes..
Scott Fella Wed, 01/09/2013 - 08:18
Well maybe the configuration was never saved and then it was rebooted without saving the changes?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Stephen Rodriguez Wed, 01/09/2013 - 08:22
So, the config on the WLC looks fine.  You do not need to do the DHCP overide under the WLAN, just have the server configured in the interface.
But out of curiosity, can you look at the switch to see if someone has enabled teh dot1q native vlan tag command?
HTH,
Steve
amankhang Wed, 01/09/2013 - 08:52
Yes the switch Port (gig interface 1/0/2) to which the WLAN is connectd is dot1q. i.e., trunk port right....?
find this:
SW1#show interfaces trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/2     on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/2     1-4094
Port        Vlans allowed and active in management domain
Gi1/0/2     1-3
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/2     1-3
It is just a basic setup with a single vlan i.e., default vlan 1 and with router, WLAN and acces points.
Stephen Rodriguez Wed, 01/09/2013 - 09:11
pull a show run of the switch, there might be a command that is vlan dot1q tag native.  it changes the behavior of the switch.  If it somehow got enabled, turn it off.
HTH,
Steve
amankhang Wed, 01/09/2013 - 20:36
weather dhcp server over ride checked are not but still not able to get the dhcp ip..
as the client laptops wifi adapter says limited connectivity and gets ip address of 169.17.x.x some thing..
i.e., no dhcp ip address.
amankhang Wed, 01/09/2013 - 20:51
will this be the issue as i am using the thwo sets of passwords to get connected to the wifi. (Keysize=104bits, Key Index=1&2, Encryption key=*************, Key format= ASCII)
Correct Answer
kcnajaf@25070 Wed, 01/09/2013 - 21:12
Najaf
amankhang Wed, 01/09/2013 - 23:10
Solved
Thank you Guys.
Changed the single set index key to access the wifi and got the dhcp working fine....
but recreated agin the same problem in order toconfirm it. as with two set of keys it dosent provide the dhcp itself where as with single set of index key it works fine..
Dont know why there is different set index keys option is it releated to some other things.
Login or Register to take actions
Posted January 8, 2013 at 6:01 AM
Stats:
Replies:36 Avg. Rating:5
Views:1091 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
