!!!!!Error Logs on Nexus 7K (7018)
Answered Question
Jan 8th, 2013
Hi Team,
We are getting some repeated error logs like below.
Please help us resolve this issue, is it any major error?????
2013 Jan  8 22:26:56 NOSCPXX-NX7K001 %ARP-3-DUP_VADDR_SRC_IP:  arp [4234]  Source address of packet received from 0050.5697.01
8f on Vlan1700(port-channel1) is duplicate of local virtual ip, 10.155.1.253
2013 Jan  8 22:27:31 NOSCPXX-NX7K001 last message repeated 3 times
2013 Jan  8 22:28:59 NOSCPXX-NX7K001 last message repeated 1 time
2013 Jan  8 22:30:21 NOSCPXX-NX7K001 last message repeated 6 times
By
Senthil
Correct Answer by Andras Dosztal about 1 year 3 months ago
Yes, you're right. Change the server's address to something else.
Correct Answer by ogamanya@storte... about 1 year 3 months ago
The MAC belongs to a VM (0050.). So there is a VM on the network which has been assigned same IP as your box. You can trace the MAC address to the switch port it is connected
Average Rating: 4.7 (3 ratings)
Andras Dosztal Tue, 01/08/2013 - 21:16
Station 0050.5697.018f (in VLAN 1700, connecting to Po1) is using the same IP address (10.155.1.253) that you set on your 7k.
balakrishnansenthil Tue, 01/08/2013 - 21:31
Hi ,
The Po1 is going to hsrp to other 7k002 for redundancy....
NX7K001# sh run int po1
!Command: show running-config interface port-channel1
!Time: Wed Jan  9 13:28:42 2013
version 5.2(1)
  description VPC Peer link to NX7K02
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 1-699,999-4094
  spanning-tree port type network
  vpc peer-link
Correct Answer
ogamanya@storte... Tue, 01/08/2013 - 22:00
balakrishnansenthil Tue, 01/08/2013 - 23:45
Thanks for update
As per below logs the MAC address is located in one of the Nexus 1000v.
You mean  the server "VWSIDSG" assigned same IP as : 10.155.1.253, am i right?
N1KVSM1#  sh mac address-table | i 0050.5697.018f
1700      0050.5697.018f    static  0         Veth72                         3
1700      0050.5697.018f    dynamic 66        Po2                            4
1700      0050.5697.018f    dynamic 248       Po1                            5
N1KVSM1#
N1KVSM1#
N1KVSM1# sh run int Veth7
!Command: show running-config interface Vethernet72
!Time: Wed Jan  9 15:40:27 2013
version 4.2(1)SV1(4a)
  inherit port-profile SG_Int_DEV_App-1700
  description VWSIDSG, Network Adapter 1
  vmware dvport 1482 dvswitch uuid "75 eb 17 50 81 f5 c7 5a-ce da cb 27 d0 7d db ab"
  vmware vm mac 0050.5697.018F
N1KVSM1#
Correct Answer
Andras Dosztal Wed, 01/09/2013 - 00:38
Login or Register to take actions
Posted January 8, 2013 at 7:06 PM
Stats:
Replies:5 Avg. Rating:4.66667
Views:390 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
1 14,997
2 8,150
3 7,720
4 7,083
5 6,723
175
80
74
55
50
