3602i CAP unable to join WLC 5508
ahmedbishry
Hi All,
Hope to you a very happy new year,
I have an (AIR-CAP3602i-E-K9) and I tried to join it to WLC 5508 but I'm facing an error,
I get this error from the LAP 1310 console as below:
Reading cookie from SEEPROM
Base Ethernet MAC address: 60:73:5c:ad:cb:9c
Boot CMD: 'boot  flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx;flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...#####################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entry point: 0x2003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3600 Software (AP3G2-RCVK9W8-M), Version 15.2(2)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 23-Aug-12 02:43 by prod_rel_team
Initializing flashfs...
flashfs[2]: 6 files, 3 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 31997952
flashfs[2]: Bytes used: 7015936
flashfs[2]: Bytes available: 24982016
flashfs[2]: flashfs fsck took 9 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 12257280
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 12256256
flashfs[3]: flashfs fsck took 0 seconds.
flashfs[3]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Warning:  the compile-time code checksum does not appear to be present.
cisco AIR-CAP3602I-E-K9    (PowerPC) processor (revision A0) with 180214K/81920K bytes of memory.
Processor board ID FCZ1642J01K
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.3.1.73
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 60:73:5C:AD:CB:9C
Part Number                          : 73-14521-02
PCA Assembly Number                  : 800-37501-02
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16352BJ0
Top Assembly Part Number             : 800-35852-02
Top Assembly Serial Number           : FCZ1642J01K
Top Revision Number                  : C0
Product/Model Number                 : AIR-CAP3602I-E-K9
% Please define a domain-name first.
logging facility kern
% Invalid input detected at '^' marker.
logging trap emergencies
Press RETURN to get started!
*Mar  1 00:00:10.355: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:11.971: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:12.575: %SYS-5-RESTART: System restarted --
Compiled Thu 23-Aug-12 02:43 by prod_rel_teamlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:13.603: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:15.387: DPAA Initialization Complete
*Mar  1 00:00:15.387: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:15.979: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
no bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:32.327: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C2960S-48FPD-L (10bd.18a5.6082)
*Mar  1 00:00:48.579: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.114.42.204, mask 255.255.255.128, hostname AP6073.5cad.cb9c
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (10.114.44.129) (8.8.8.8)
*Mar  1 00:00:59.459: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.114.44.131 obtained through DHCP
*Mar  1 00:00:59.459: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:00.015: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:01:00.015: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CIR906.WLC.5508'running version 7.0.235.3 is rejected.
*Mar  1 00:01:00.015: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:00.015: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:00.015: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:00.015: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.114.44.131
*Mar  1 00:01:10.015: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CIR906.WLC.5508'running version 7.0.235.3 is rejected.
*Mar  1 00:01:10.015: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:10.015: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:10.015: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:10.015: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.114.44.131
*Mar  1 00:01:20.015: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CIR906.WLC.5508'running version 7.0.235.3 is rejected.
*Mar  1 00:01:20.015: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:20.015: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:20.015: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:20.015: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.114.44.131
*Mar  1 00:01:30.015: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CIR906.WLC.5508'running version 7.0.235.3 is rejected.
*Mar  1 00:01:30.015: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:30.015: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:30.015: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:30.015: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.114.44.131
*Mar  1 00:01:32.343: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C2960S-48FPD-L (10bd.18a5.6082)
*Mar  1 00:01:40.015: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CIR906.WLC.5508'running version 7.0.235.3 is rejected.
*Mar  1 00:01:40.015: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:40.015: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:40.015: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:40.015: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.114.44.131
Not in Bound state.
*Mar  1 00:01:55.515: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:02:02.519: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:02:02.555: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.114.42.205, mask 255.255.255.128, hostname AP6073.5cad.cb9c
*Mar  1 00:02:06.515: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.114.44.131 obtained through DHCP
*Mar  1 00:02:06.515: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:02:06.631: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:02:06.631: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CIR906.WLC.5508'running version 7.0.235.3 is rejected.
*Mar  1 00:02:06.631: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:02:06.631: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:02:06.631: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:02:06.631: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.114.44.131
*Mar  1 00:02:16.631: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CIR906.WLC.5508'running version 7.0.235.3 is rejected.
*Mar  1 00:02:16.631: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:02:16.631: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:02:16.631: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:02:16.631: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.114.44.131
*Mar  1 00:02:26.631: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CIR906.WLC.5508'running version 7.0.235.3 is rejected.
*Mar  1 00:02:26.631: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:02:26.631: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:02:26.631: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:02:26.631: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.114.44.131
Please Advise,
Thanks in Advanced,
Ahmed,
Leo Laohoo
Your WLC is running a 7.0.235.3.  This firmware is suitable for your 1300 but you need at least 7.2.X to run 3600.
7 Replies 7
Leo Laohoo
Leo is right if you do have 1310's though, you might be in a bind as the 1310's are not supported on the v7.2
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
-Scott
Leo Laohoo
As I've mentioned in your other thread, you can get a refurbished 4402/4404 cheap from Cisco Refurbished.  You can use the 4400 to run your 1310 and the 5508 to run the newer APs.
Ah there is another thread:)
-Scott
Dear Scott,
Many thanks for your kind reply,
Ahmed,
Dear Leo,
I believe I should take your advise,
Ahmed,
Thanks for your ratings, Ahmed.
