Outbound calls from UCM not possible to pstn gateway (lab)
Answered Question
Jan 12th, 2013
I'm not able to place outbound calls to my pstn gateway, as far as i know i configured everything properly:
To make everything short:
I configured my branch2 router as a mgcp gateway
Bottom - up
sh isdn status => multiple frame esthablised
sh ccm-manager=>
MGCP Domain Name: BR1-RTR.proctorlabs.com
Priority        Status                   Host
Primary         Registered               10.10.210.10
Current active Call Manager:    10.10.210.10
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            21:41:24 UTC Jan 12 2013 (elapsed time: 00:00:08)
Last MGCP traffic time:         21:41:24 UTC Jan 12 2013 (elapsed time: 00:00:08)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Immediate
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
In callmanager i created a route pattern ( 91617.XXXXXXX) and i'v pointed it out to the gateway (MGCP)
My mgcp gateway in callmanager is also registered
I want to call to my pstn gateway to this number 16178632683 it has to go via the branch 1 gateway.
When i debug isdn q931 it says unallocated /unassigned number
(The 9 is an outside prefix)
Backwards i'm able to call from my pstn phone to my branch phones that part is fine.
Is there something i missed?
Branch1 gateway config:
Building configuration...
Current configuration : 2916 bytes
version 12.4
hostname BR1-RTR
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$wNOA$XSwMLgrwkVM.XnurXmwyJ.
no aaa new-model
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
ip domain name proctorlabs.com
no ipv6 cef
isdn switch-type primary-ni
voice-card 0
archive
log config
  hidekeys
controller T1 0/2/0
pri-group timeslots 1-3,24 service mgcp
controller T1 0/2/1
interface Loopback0
ip address 10.10.110.2 255.255.255.255
ip ospf network point-to-point
interface FastEthernet0/0
ip address 10.10.210.16 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
switchport trunk native vlan 130
switchport mode trunk
switchport voice vlan 240
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/3/0
ip address 10.10.111.2 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
interface Serial0/3/1
no ip address
clock rate 2000000
interface Vlan1
no ip address
interface Vlan130
ip address 10.10.101.1 255.255.255.0
interface Vlan240
ip address 10.10.201.1 255.255.255.0
ip helper-address 10.10.210.10
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
disable-eadi
control-plane
voice-port 0/2/0:23
ccm-manager switchback immediate
ccm-manager redundant-host 10.10.210.10
ccm-manager mgcp
ccm-manager fax protocol cisco
mgcp
mgcp call-agent 10.10.210.10 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
dial-peer voice 91617 pots
destination-pattern 91617.8632683
port 0/2/0:23
forward-digits 10
gatekeeper
shutdown
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
password cisco
login
transport preferred none
transport input telnet
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
scheduler allocate 20000 1000
end
Correct Answer by Ayodeji oladipo... about 1 year 3 months ago
The question is on the PSTN CCME gateway, do you have an ephone-dn with extension "8632683"
The PSTN gateway is saying that htere is no extension with that number on it. You didnt sent the sh run on your PSTN gateway. Does that extension exist on your PSTN gateway...
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Average Rating: 0 (3 ratings)
yahsiel2004 Sat, 01/12/2013 - 13:05
What is your carrier expecting a 9? You have configured route pattern 91617.XXXXXXX which strips 91617 before going out the GW. If the carrier is not expecting a 9 you should configure your route pattern as 9.1617XXXXXXX and if 617 is a local number you shouldn't include a 1.
Yosh
Ayodeji oladipo... Sat, 01/12/2013 - 14:15
The first place to start is to send the output of  "debug isdn q93"
We need to see what the CUCM is sending to the gateway.The second this is have you configured any digit strip option on your route pattern in cucm? Are you stripping pre dot or you are not stripping at all...If you are not stripping any digit, then you are sending the full 91617XXXXXX to your provider and as such you need to strip the 9...
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
monasir81 Sun, 01/13/2013 - 10:48
@ yahsiel 2004:
to make everything clear this is for lab purposes not in a real live environment.
The task is that i have to create a route pattern as mentioned ( 9 is a prefix then 1617) then 7 further digits.
@ aokanlawon:
I am stripping predot as stripping option in cucm.
So that means 91617 is going to be stripped (.) everything afhter the . is 7 further digits.
I did a debug isdn q931
The result is there isn't  "unassigned/unallocated number"
You can see that the call is trying to send out of the gateway but afhter that you hear busy tone.
Backwards from my pstn voicegateway i am able to call to the branch1 phones.
Somehowe something is going wrong??
Jaime Valencia Sun, 01/13/2013 - 10:56
The other end doesn't know how to route the call, check your DP config if H323, and inbound CSS in GW config.
Ayodeji oladipo... Sun, 01/13/2013 - 11:09
Like Jamie suggested,
You need to look at the terminating gateway in your lab..
Do a debug isdn q931 on that side...Does the call arrive on that gateway...
Is there a phone configured with that number on that gateway..
The pstn gateway I believe is a ccme gateway. Have a look there...If you want to send us the config and the debug..
monasir81 Wed, 01/16/2013 - 04:06
Hi there,
That's right, the pstn gateway is CME based.
The goal is to make an outgoing call to the pstn gateway " but true the BR1 gateway "
The Br2 gateway needs to be mgcp protocol based.
I have that part configured, the only problem what is left is that the call is not arriving at the gateway.
First i thought i have to make an dial-peer, but i already created a routepattern in cucm.
My pstn is provided with the necessary dial-peers for incoming and outgoing calls.
91617.XXXXXXX is also defined for the br1 gateway on this routepattern.
digitstrip option is:Predot
The 9 would be leading
Ayodeji oladipo... Wed, 01/16/2013 - 07:56
You want to make outbound calls to the pstn through Br1 gateway? Are the Br1 phones registered to cucm? If they are all they need is to have access to the RP on cucm and cucm will send the calls to the PSTN gateway if you have configured it like that
monasir81 Thu, 01/17/2013 - 02:28
Hi aokanlawon,
All of my br1 phones are registered.
I have a routepattern created.
=>901617.XXXXXXX
Still no phones go outbound (unallocated/unassigned number) by debug isdn q931
I have to troubleshoot to find more.
I get back on this
Ayodeji oladipo... Thu, 01/17/2013 - 03:10
From the PSTN gateway, ( I assume this is a h323 gateway on cucm)
send the ff debug:
debug isdn q931...
debug voip ccapi inout
monasir81 Thu, 01/17/2013 - 03:51
Hi aokanlawon,
This is not a h323 gateway.
This is callmanager express based
Ayodeji oladipo... Thu, 01/17/2013 - 03:55
So I believe this is your call flow then,....
CUCM---->Br1----E1/PSTN----PSTN Gateway..
SO call go from CUCM to Br1 Gw and then to PSTN..
OK..
How is the br1 gateway cofigured. is it h323 gateway in cucm?
So go to br1 gateway..sebd debug isdn q931 and debug voip ccapi inout..
go to PSTN gateway send debug isdn q931
monasir81 Fri, 01/18/2013 - 11:48
Hi aonkanlawon,
That's right that's the call flow.
The call has to be sent to the PSTN router via the Branch1 router.
The Branch router isn't configured as h323 gateway in cucm but as MGCP.
Here is my output generation of the branch 1 router:
Jan 18 19:59:49.175: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0002
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Display i = 'BR1 Phone 1'
Calling Party Number i = 0x0081, '6178631001'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '8632683'
*Jan 18 19:59:49.207: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8002
*Jan 18 19:59:49.215: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8002
Cause i = 0x8281 - Unallocated/unassigned number
*Jan 18 19:59:49.643: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x0002
*Jan 18 19:59:49.651: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8002
Here is my output of my PSTN router when i call to a pstn number:
Jan 18 21:02:52.931: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0002
Standard = CCITT
Jan 18 21:02:52.935: ISDN Se0/1/0:23 Q931: Received SETUP  callref = 0x8002 callID = 0x0002 switch = primary-ni interface = Network
Jan 18 21:02:52.955: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8002
Jan 18 21:02:52.959: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8002
Jan 18 21:02:53.391: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0002
Jan 18 21:02:53.395: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8002
Here is output of debug voip ccapi inout:
Jan 18 20:03:24.463: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x6855E404, Interface Type=6, Destination=, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D000000001e65248000000F500000003)
*Jan 18 20:03:24.463: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jan 18 20:03:24.463: :cc_get_feature_vsa malloc success
*Jan 18 20:03:24.463:  cc_get_feature_vsa count is 1
*Jan 18 20:03:24.463: :FEATURE_VSA attributes are: feature_name:0,feature_time:1762501704,feature_id:11
*Jan 18 20:03:24.463: //11/F340FB1A8007/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Jan 18 20:03:24.463: //11/F340FB1A8007/CCAPI/ccCallSetContext:
   Context=0x68D0E9D8
*Jan 18 20:03:24.467: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x67FA7A50, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
*Jan 18 20:03:24.467: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jan 18 20:03:24.467: :cc_get_feature_vsa malloc success
*Jan 18 20:03:24.467:  cc_get_feature_vsa count is 2
*Jan 18 20:03:24.467: :FEATURE_VSA attributes are: feature_name:0,feature_time:1762501480,feature_id:12
*Jan 18 20:03:24.467: //12/F340FB1A8007/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
*Jan 18 20:03:24.467: //12/F340FB1A8007/CCAPI/ccCallSetContext:
   Context=0x68D0E7C8
*Jan 18 20:03:24.471: //12/F340FB1A8007/CCAPI/cc_api_call_connected:
   Interface=0x67FA7A50, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Jan 18 20:03:24.471: //11/F340FB1A8007/CCAPI/cc_api_call_proceeding:
   Interface=0x6855E404, Progress Indication=NULL(0)
*Jan 18 20:03:24.475: //11/F340FB1A8007/CCAPI/cc_api_call_connected:
   Interface=0x6855E404, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
*Jan 18 20:03:24.475: //11/F340FB1A8007/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x689B3628, Call Id=11
*Jan 18 20:03:24.475: //11/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0xB, digit_event=0x1, enable=TRUE, consume=FALSE)
*Jan 18 20:03:24.475: //11/F340FB1A8007/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=11
*Jan 18 20:03:24.475: //11/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x6855E404, callID=0xB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Jan 18 20:03:24.475: //11/F340FB1A8007/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x6855E404, Call Id=11
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
*Jan 18 20:03:24.475: //11/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x689B383C, callID1=0xB, callID2=0xC, tag=0x0)
   (confID=0x689B383C, callID1=0xB, gcid=0-0-0-0, tag=0x0)
*Jan 18 20:03:24.475: //12/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x689B383C, callID2=0xC, gcid=0-0-0-0, tag=0x0)
*Jan 18 20:03:24.475: //11/F340FB1A8007/CCAPI/ccConferenceCreate:
   Conference Id=0x689B383C, Call Id1=11, Call Id2=12, Tag=0x0
*Jan 18 20:03:24.479: //11/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x6, Source Interface=0x6855E404, Source Call Id=11,
   Destination Call Id=12, Disposition=0x0, Tag=0xFFFFFFFF
*Jan 18 20:03:24.479: //12/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x6, Source Interface=0x67FA7A50, Source Call Id=12,
   Destination Call Id=11, Disposition=0x0, Tag=0x0
*Jan 18 20:03:24.479: //11/F340FB1A8007/CCAPI/cc_generic_bridge_done:
*Jan 18 20:03:24.479: //11/F340FB1A8007/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x6, Destination Call Id=12)
*Jan 18 20:03:24.479: //12/F340FB1A8007/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x6, Destination Call Id=11)
*Jan 18 20:03:24.479: //11/F340FB1A8007/CCAPI/cc_api_caps_ind:
   Destination Interface=0x67FA7A50, Destination Call Id=12, Source Call Id=11,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Jan 18 20:03:24.479: //12/F340FB1A8007/CCAPI/cc_api_caps_ind:
   Destination Interface=0x6855E404, Destination Call Id=11, Source Call Id=12,
   Caps(Codec=0x4, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
*Jan 18 20:03:24.479: //12/F340FB1A8007/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=4386)
*Jan 18 20:03:24.483: //11/F340FB1A8007/CCAPI/cc_api_caps_ack:
*Jan 18 20:03:24.483: //11/F340FB1A8007/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x6855E404, Call Id=11
*Jan 18 20:03:24.483: //11/F340FB1A8007/CCAPI/cc_api_voice_mode_event:
   Call Id=11
*Jan 18 20:03:24.487: //11/F340FB1A8007/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x68D0E9D8)
*Jan 18 20:03:24.487: //11/F340FB1A8007/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x6, Call Id1=11, Call Id2=12
*Jan 18 20:03:24.487: //11/F340FB1A8007/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
*Jan 18 20:03:24.491: //11/F340FB1A8007/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=11
*Jan 18 20:03:24.491: //11/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
*Jan 18 20:03:24.491: //11/F340FB1A8007/CCAPI/ccCallReportDigits:
*Jan 18 20:03:24.491: //11/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
*Jan 18 20:03:24.491: //11/F340FB1A8007/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
*Jan 18 20:03:24.663: //11/F340FB1A8007/CCAPI/ccCallModifyExtended:
   Nominator=0x689B3558, Params=0x689B27A8, Call Id=11
*Jan 18 20:03:24.667: //12/F340FB1A8007/CCAPI/ccCallModify:
   Nominator=0x18E30, Params=0x689B29A8, Call Id=12
*Jan 18 20:03:24.667: //11/F340FB1A8007/CCAPI/cc_api_call_modify_done:
*Jan 18 20:03:24.667: //12/F340FB1A8007/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x67FA7A50, Call Id=12
*Jan 18 20:03:24.831: //11/F340FB1A8007/CCAPI/ccCallModifyExtended:
*Jan 18 20:03:24.835: //12/F340FB1A8007/CCAPI/ccCallModify:
   Nominator=0x80000800, Params=0x689B29A8, Call Id=12
*Jan 18 20:03:24.835: //11/F340FB1A8007/CCAPI/cc_api_call_modify_done:
*Jan 18 20:03:24.835: //12/F340FB1A8007/CCAPI/cc_api_call_modify_done:
*Jan 18 20:03:24.903: //11/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0xB, digit_event=0x0, enable=FALSE, consume=FALSE)
*Jan 18 20:03:24.903: //11/F340FB1A8007/CCAPI/ccCallReportDigits:
*Jan 18 20:03:24.903: //11/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x6855E404, callID=0xB, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Jan 18 20:03:24.903: //11/F340FB1A8007/CCAPI/cc_api_call_report_digits_done:
*Jan 18 20:03:24.903: //12/F340FB1A8007/CCAPI/ccGetCallStatistics:
   Call Stats=0x68D1E73C, Call Id=12
*Jan 18 20:03:24.903: //11/F340FB1A8007/CCAPI/ccConferenceDestroy:
   Conference Id=0x6, Tag=0x0
*Jan 18 20:03:24.903: //11/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=12, Disposition=0x0, Tag=0x0
*Jan 18 20:03:24.907: //12/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Jan 18 20:03:24.907: //11/F340FB1A8007/CCAPI/cc_generic_bridge_done:
*Jan 18 20:03:24.907: //11/F340FB1A8007/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Jan 18 20:03:24.907: //11/F340FB1A8007/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Jan 18 20:03:24.907: //12/F340FB1A8007/CCAPI/ccCallDisconnect:
*Jan 18 20:03:24.915: //12/F340FB1A8007/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x67FA7A50, Tag=0x0, Call Id=12,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Jan 18 20:03:24.915: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jan 18 20:03:24.915: :cc_free_feature_vsa freeing 690DA360
*Jan 18 20:03:24.915:  vsacount in free is 1
*Jan 18 20:03:24.927: //11/F340FB1A8007/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6855E404, Tag=0x0, Call Id=11,
*Jan 18 20:03:24.927: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jan 18 20:03:24.927: :cc_free_feature_vsa freeing 690DA440
*Jan 18 20:03:24.927:  vsacount in free is 0
Ayodeji oladipo... Fri, 01/18/2013 - 12:12
So the call arrives o n the PSTN router, but it doesnt match any number..is there a phone configured with this extension?
The PSTN is disconnecting the call and sying that it doesnt have any extension with this number 6178631001.
Please check your config. You can send a sh run here
monasir81 Fri, 01/18/2013 - 12:42
The extension which i'm trying to call is +16178632683. (pstn phone at PSTN site)
I am calling from one of my ucm phones that are all registered.
By example from hq phone with extension ( 2123945001) to pstn phone with extension +16178632683.
I created a routepattern like i mentioned ( 91617.XXXXXXX) digitstrip is Predot
So that means 91617 will be stripped of , so in this case the called number will be 8632683 instead of (+1617862683)
Calling number is 6178631002 from one of my cucm phones.
i am going to send you the neccary info of my pstn & branch config
PSTN-WAN#sh run | b voice trans
voice translation-rule 1
rule 2 /^\(2123942123\)$/ /\1/ type any subscriber plan any isdn
rule 3 /^6178632683$/ /\0/ type any national plan any isdn
rule 4 /^32141891$/ /34\0/ type any international plan any isdn
rule 5 /^6745738932$/ /91\0/ type any international plan any isdn
rule 6 /^9004522138$/ /\0/ type any national plan any isdn
voice translation-rule 2
rule 1 /^911$/ /\0/ type any unknown plan any unknown
rule 2 /^2123942123$/ /\0/ type any national plan any isdn
rule 3 /^617\(8632683\)$/ /\1/ type any subscriber plan any isdn
voice translation-rule 3
rule 1 /^911$/ /999/ type any unknown plan any unknown
rule 2 /^2123942123$/ /1\0/ type any international plan any isdn
rule 3 /^6178632683$/ /1\0/ type any international plan any isdn
rule 4 /^32141891$/ /\0/ type any national plan any isdn
rule 6 /^9004522138$/ /1\0/ type any international plan any isdn
voice translation-rule 34
rule 1 /^011/ /1234/
rule 2 /^911$/ /1234/
rule 3 /^1617/ /1234/
rule 4 /^1212/ /1234/
rule 5 /^212/ /1234/
rule 6 /^394/ /1234/
rule 7 /^617/ /1234/
rule 8 /^863/ /1234/
voice translation-rule 212
rule 1 /^1212/ /1234/
rule 2 /^1/ /\0/
rule 3 /^394/ /\0/
rule 4 /^011/ /\0/
rule 5 /^212/ /\0/
rule 6 /^911$/ /\0/
rule 9 /./ /1234/
voice translation-rule 617
rule 1 /^1617/ /1234/
rule 2 /^1/ /\0/
rule 3 /^863/ /\0/
rule 4 /^011/ /\0/
rule 5 /^617/ /\0/
rule 6 /^911$/ /\0/
rule 9 /./ /1234/
voice translation-profile block-call-into-BR1
translate called 617
voice translation-profile block-call-into-BR2
translate called 34
voice translation-profile block-call-into-HQ
translate called 212
voice translation-profile display-proper-ani-into-BR1
translate calling 2
voice translation-profile display-proper-ani-into-BR2
translate calling 3
voice translation-profile display-proper-ani-into-HQ
translate calling 1
voice-card 0
archive
log config
  hidekeys
controller E1 0/0/0
clock source internal
pri-group timeslots 1-3,16
description ** E1 VOICE CONNECTION TO BR2-RTR **
controller T1 0/1/0
pri-group timeslots 1-3,23-24
description ** T1 VOICE CONNECTION TO HQ-RTR **
controller T1 0/1/1
channel-group 0 timeslots 1-24
description ** SERIAL DATA CONNECTION TO HQ-RTR **
controller T1 0/3/0
description ** T1 VOICE CONNECTION TO BR1-RTR **
controller T1 0/3/1
description ** SERIAL DATA CONNECTION TO BR1-RTR **
PSTN-WAN#sh run | s dial-peer
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
dial-peer voice 201 voip
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 3 pots
destination-pattern 9T
port 0/0/0:15
dial-peer voice 103 pots
destination-pattern 32143...
port 0/0/0:15
forward-digits 8
dial-peer voice 104 pots
no digit-strip
port 0/0/0:15
prefix +34
dial-peer voice 101 pots
destination-pattern 2123945...
port 0/1/0:23
forward-digits 10
dial-peer voice 102 pots
destination-pattern 6178631...
port 0/1/0:23
forward-digits 10
BR1-RTR#sh run
Current configuration : 2818 bytes
version 12.4
hostname BR1-RTR
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
controller T1 0/2/0
controller T1 0/2/1
interface Loopback0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
encapsulation hdlc
no cdp enable
encapsulation ppp
ip ospf mtu-ignore
no ip address
clock rate 2000000
interface Vlan1
no ip address
interface Vlan130
interface Vlan240
router ospf 1
no ip http server
disable-eadi
control-plane
voice-port 0/2/0:23
ccm-manager mgcp
mgcp
gatekeeper
shutdown
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
password cisco
login
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
end
Correct Answer
Ayodeji oladipo... Fri, 01/18/2013 - 15:47
monasir81 Sat, 01/19/2013 - 12:10
I'm still struggling with this awful translation rules.
It's good that you mentioned about your last response.
You are right my pstn phone hasn't got an extension with 8632683.
It has an ephone - dn with 16178632683.
if i create a routepattern in cucm with 1617XXXXXXX then the call gets routed.
But what is the best way to get this construction work....
In cucm i have a routerpattern with 91617.XXXXXXX (want to call at pstn site phone with ephone-dn 16178632683
What is the best way to utilize this.
So that when i call from one of my cucm phones to the "called number 8632683" the call will be translate to 16178632683
What is the best way to make this voice translation rule in my pstn gateway
Ayodeji oladipo... Sat, 01/19/2013 - 18:30
You can configure translation rule on the PSTN gateway like this...
voice translation-rule 4
rule 1 /^8632683/ /16178632683/
voice translation-profile br2CLI
translate called 4
then apply it on the dial-peer 100
translation-profile incoming br2CLI
monasir81 Sun, 01/20/2013 - 12:26
Hi aonkanlawon,
Unfortunately the configurations didn't work.
I think that some translation rules in my pstn gateway are overlapping.
Because from the pstn site i am able to call to all of my ucm phones.
Ayodeji oladipo... Sun, 01/20/2013 - 13:34
Ok. Send the sh run of your PSTN gateway. try and attach it in a text file
Harmit Singh Mon, 01/21/2013 - 08:04
+5 for my friend Deji for the excellent advice.
Hi Mohamed,
Here is what I see from the debug you posted for the PSTN gateway:
Standard = CCITT
The number 8632683 needs to be mapped to an ephone-dn on your PSTN phone or it needs to be translated to 16178632683 which is already on your PSTN phone. Then the call would work. Based on the Route Pattern you mentioned -
91617.XXXXXXX, if you predot digit strip, then only 8632683 would go to the PSTN gateway. However, if you set it to
9.1617XXXXXXX, then the call should go through fine since your PSTN phone has 16178632683 as a DN.
HTH.
Harmit.
monasir81 Mon, 01/21/2013 - 10:26
Hi guys,
Finally it worked!
I've changed the routepattern to 9.1617XXXXXXX
Nowe the call gets sent out t the pstn....
pfff i'm very thankful to all of you .
@aokanlawon thanks for your patience.
As we can see patience is the key to success.
There is definetely a mistake in the ipexpert workbook.
Because it is not correct.
Ayodeji oladipo... Mon, 01/21/2013 - 13:33
Monasir,
I have rated Harmit post for you. Its very important to appreciate the help we recieve on the forum. +5 Harmit.
Harmit suggestion is one way it can work. The way you have configured can also work. And I suggest you learn it also. It shows that your translation rule is not configured properly. Take some time to leanr that because its important too.
Good luck
Login or Register to take actions
Posted January 12, 2013 at 12:39 PM
Stats:
Replies:22 Avg. Rating:
Views:622 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
1 21,026
2 15,047
3 10,314
4 7,999
5 4,856
120
90
67
65
51
