Warning message
UC560 - Nightly automated backup - Possible?
Jan 14th, 2013
I have an UC560 system. I would like to schedule a nightly backup job to backup all configuration and voice mails. Is it possible? Configuration doesn't change much on daily basis but the voicemails do and need a way to back them up unattended.
Please point me to right direction if you have figured out a good work around or solution.
johschaf Mon, 01/14/2013 - 13:53
  • Silver, 250 points or more
This is not possible through CCA, but you can use CLI and the CUE web gui to do this. There are also 3rd party tools you can use to do the automated backups.
See this post for the more info about backups: https://supportforums.cisco.com/thread/2155698
Here is an example how you would do this in CME:
kron occurrence monthly at 01:23 june 20 recurring
  policy-list save-config
kron policy-list save-config
  cli copy system:/running-config tftp://192.168.1.2/router-confg.txt
In the CUE web GUI under Administration you need to define the backup server. Then you can create a scheduled backup.
You will need FTP and TFTP servers running somewhere to backup the configurations and data to.
Hope this helps.
-john
