QoS isn't working properly in Catalyst 6500
Jan 17th, 2013
Hi All,
Not sure if anyone also experienced the similar issue as i did. I'm having Cisco Catalyst with GE module (WS-X6748-GE-TX). I'm trying to limit bandwidth for a customer to 4Mbps but the bandwidth always exceed to 5Mbps or more than this. I've verified the QoS configuration, it seems to be correct. Any idea what is the possible issue? Any bug or any IOS/Module of the switch problem? Below are device spec. and configuration.
Appreciate any response.
#show module 1
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL13442T95
#show version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 27-Oct-09 11:12 by prod_rel_team
#show mls qos
  QoS is enabled globally
  Policy marking depends on port_trust
  QoS ip packet dscp rewrite enabled globally
  QoS serial policing mode disabled globally
  Input mode for GRE Tunnel is Pipe mode
  Input mode for MPLS is Pipe mode
  Vlan or Portchannel(Multi-Earl) policies supported: Yes
  Egress policies supported: Yes
  QoS 10g-only mode supported: Yes [Current mode: Off]
#show policy-map 4Mbps
  Policy Map 4Mbps
    Class class-default
     police cir 4000000 bc 128000 be 128000
       conform-action transmit
       exceed-action drop
       violate-action drop
#show run int gi1/5
Building configuration...
Current configuration : 188 bytes
interface GigabitEthernet1/5
ip address X.X.X.X mask X.X.X.X
service-policy input 4Mbps
service-policy output 4Mbps
Vannara Vuth Thu, 01/17/2013 - 18:48
Hi Paul, Thanks for your reply. I've red the above link and a few others related topics, however i'm yet still not able to pinpoint the cause of this issue. I've also red below link and not sure if it is really the cause. I checked the switch interface and found the port was set to "untrusted". If you found out something wrong, kindly share with me.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008074d6b1.shtml#topic2
#show queueing interface gigabitEthernet 1/5
Interface GigabitEthernet1/5 queueing strategy:  Weighted Round-Robin
  Port QoS is enabled
Trust boundary disabled
  Port is untrusted
  Extend trust state: not trusted [COS = 0]
  Default COS is 0
    Queueing Mode In Tx direction: mode-cos
    Transmit queues [type = 1p3q8t]:
Vannara Vuth Wed, 01/23/2013 - 04:04
Hi All,
Any idea on above matter? Hope for any reply from you guys.
