VPN AnyConnect Client and Win8
Jan 17th, 2013
Hi, I'm a bit new to firewalls, so still trying to get to grips with it. I need to connect to an ASA 5510 with asa825-k8.
We currently can connect to it with a normal IPsec VPN client. I tried using Anyconnect client, version anyconnect-win-3.1.01065-pre-deploy-k9, but the connection fails.
My question is this: If using IPsec to connect to the ASA ( as opposed to SSL) does the config on the ASA need to be amended to be able to accept the proposals from the AnyConnect client?
dewaldt05 Thu, 01/17/2013 - 07:41
thanks for the response. I realise that ssl vpn ipsec vpn are different. anyconnect support ipsec connections in addition to ssl vpn, right? so, if iusing the anyconnect for ipsec vpn instead of ssl vpn, does the existing, working ipsec vpn need to be amended to accept ipsec vpn when using anyconnect client?
Rudy Sanjoko Thu, 01/17/2013 - 08:13
  • Silver, 250 points or more
I think you missunderstood, they are different, you will need to use cisco vpn client for ipsec vpn and anyconnect for ssl vpn, you can't use anyconnect for ipsec vpn.
Related Content
