01-18-2013 01:58 PM
My problem is that the switch all of the sudden doesn't boot up anymore. The System LED constantly flashes, after probably 40-50 seconds or so it constantly lights for a second, afterwards all the lights on the ethernet ports light up for a second and the process starts all over again!
The console messages:
Device configuration:
Slot 1 - SG300-10P
Device 0: GT_98DX3033B (AlleyCat2)
-- Unit Standalone --
Tapi Version: v1.9.5
Core Version: v1.9.5
19-Jul-2012 17:55:03 %INIT-I-InitCompleted: Initialization task is completed
19-Jul-2012 17:55:13 %SNMP-I-CDBITEMSNUM: Number of running configuration items loaded: 239
19-Jul-2012 17:55:13 %SNMP-I-CDBITEMSNUM: Number of startup configuration items loaded: 239
19-Jul-2012 18:55:21 %3SWCOS-F-COSFAILGTCNTR: Failed to get counter on device
***** FATAL ERROR *****
Reporting Task: SNMP.
Software Version: 1.2.7.76 (date 19-Jul-2012 time 17:54:43)
***** DEBUG *****
DEBUG LOG IS EMPTY
0x16a614
0x167054
0x6bdc18
0x490518
0x4959e4
0x495bac
0x83b03c
0x83ffcc
0x5bc200
0x8aad68
0x87ca0c
0x435be8
0x437198
0x437e94
0x4386b4
0x60f3dc
0x121d3c
***************** SYSTEM RESET *****************
Board ID is 18
Device ID 0xe75a11ab
Now the procedure starts all over again...
Any clues how to resolve the issue?
I'm afraid that something is wrong with the hardware...
Regards, Andrej
01-18-2013 03:10 PM
Hi, the flash is corrupt.
Follow this document
https://supportforums.cisco.com/docs/DOC-27000
If the switches doesn't recover after this procedure, call the SBSC for a RMA.
-Tom
Please mark answered for helpful posts
01-19-2013 05:27 AM
I tried the described procedure, but the problem is the switch doesn't even let me to trigger the startup menu! It just "jumps" over it and starts with the loading of the firmware.. See the software version beneath the SNMP?
***** DEBUG *****
DEBUG LOG IS EMPTY
0x16a614
0x167054
0x6bdc18
0x490518
0x4959e4
0x495bac
0x83b03c
0x83ffcc
0x5bc200
0x8aad68
0x87ca0c
0x435be8
0x437198
0x437e94
0x4386b4
0x60f3dc
0x121d3c
Don't know how to convince the switch to jump to the Startup Menu! I just can't success to see the screen which confirms loading existing firmware after 2 seconds (it seems like the switch just jumps over this procedure...?) and starts with loading... Any other manever, advice to succesfully resolve the situation?
Regards, Andrej
01-19-2013 05:52 AM
Hi Andrej, if you can't run the recovery then you need to call the support center. It will likely result in RMA / replacement.
-Tom
09-30-2015 02:39 PM
Hi, I have the same problem but the documment that you suggest have restrictions, could you share the procedure to try it??
thanks
04-21-2016 08:58 PM
I'm facing similar issue. But I can not access https://supportforums.cisco.com/docs/DOC-27000 .....
