Slow response between VLAN’s
HCL Support
Inter-VLAN applications are slow and same VLAN it is working fine.(i.e.VLAN to VLAN applications and File transfer response was Slow).
Switch Model number           : WS-C3750G-24TS-S1U
Please help me in this case.
Akhil
mahmoodmkl
Level 7
Level 7
Can you verify whether the gateway is configured properly in the end systems.
Gateway is configured correctly on the systems.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
This is seen on just a single switch w/o any other devices in the network attached to it?
What SDM template are you using?
