01-22-2013 03:01 AM - edited 03-21-2019 06:52 AM
I have just upgraded two UC320W's to firmware version 2.3.2(6) which seemed to go well. However all the phones, SPA509G's and SPA504G's, ringtones changed. At first I logged in to them all and changed the ringtone from "Retro" to "Classic -1" as I think this is what they were on before the upgrade, but there is a 6 second space between rings. This may sound like a small issue but it makes the phones look broken, they basically ring onece then flash for six seconds before you hear another ring.
I did not see this listed in the known issues of the firmware but it has happend on the two systems I have upgraded. Has anyone else seen this and how do I fix it?
Cheers,
Tony
Solved! Go to Solution.
01-22-2013 11:19 AM
Hi Tony,
Please send me an email at wenyang@cisco.com. I will reply you with a PMF to be installed in your system to correct the ring tone.
Best regards,
Wendy
01-22-2013 07:26 AM
Hi Tony,
What 'Region' do you have configured on the two systems? Please confirm which Ringtone(s) you are experiencing the delay.
Chris
01-22-2013 07:38 AM
Hi Chris,
Region = United Kingdon
Dial Plan = Local calls are 7-Digits
We only use one ringtone "Classic-1"
Cheers,
Tony
01-22-2013 11:19 AM
Hi Tony,
Best regards,
Wendy
01-24-2013 02:09 AM
Hello Wendy,
I also had a call open with Cisco Support and they sent me cadence-1_fix.pmf which fixed the rin tone. Incidently it also fixed the Du-dut ring tone that someone else used.
Thank you,
Tony
