How to configure ADSL2+ conexion with 1941
Jan 25th, 2013
hi there,
y have a lttle problem to cofigure a ADSL2+ Conexion in an 1941 router.
line protocol are up but didn't have ip adresse in my interface...
Current configuration : 1986 bytes
! Last configuration change at 22:32:07 UTC Fri Jan 25 2013
version 15.1
service password-encryption
hostname XXXXXXXXXXXX
boot-start-marker
boot-end-marker
enable password 7 063656356B49394B4F
no aaa new-model
no ipv6 cef
ip source-route
ip cef
vpdn enable
vpdn-group pppoe
request-dialin
  protocol l2tp
controller VDSL 0/1/0
operating mode adsl2+
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.9.250 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.1.253 255.255.255.0
duplex auto
speed auto
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
pvc 8/81
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Ethernet0/1/0
no ip address
shutdown
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname uribej
ppp chap password 7 055A545C75191849
ppp pap sent-username uribej password 7 11584B5643475D4C
router rip
version 2
network 192.168.1.0
network 192.168.9.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.9.0 0.0.0.255
access-list 1 remark "Access liste por el NAT (Internet)"
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 107E500D2210225946
login
transport input all
scheduler allocate 20000 1000
end
show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         192.168.9.250   YES NVRAM  up                    up
GigabitEthernet0/1         192.168.1.253   YES NVRAM  down                  down
ATM0/1/0                   unassigned      YES unset  down                  down
Ethernet0/1/0              unassigned      YES unset  administratively down down
Dialer1                    unassigned      YES manual up                    up
NVI0                       192.168.9.250   YES unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  down                  down
i don't know how i can find the probleme, and debug's comandes no show me anything.
I'im located in mexico, and use TELMEX provider.
the conexion is an ADSL2+, and prvider's box conect them with PPPoE...
sorry for my bad english.
thank's for your help,
paolo bevilacqua Thu, 01/31/2013 - 23:10
  • Hall of Fame,
    Founding Member
Start with "show controllers vdsl".
mathieu.ranouil Mon, 02/11/2013 - 10:48
Hello and thank you for your response,
Apparently the line is detected by the controller…
Before comment, I try to put the card in "automatic"
And apparently this line doesn’t work in ADSL2+...
Router#show controllers vdsL 0/1/0
Controller VDSL 0/1/0 is UP
Daemon Status:           Up
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'ALCB'
Chip Vendor Specific:   0x0000                   0x0000
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:    FOC16454FN7 1941/K9  15.1(4)M
Serial Number Far:
Modem Version Near:    15.1(4)M
Modem Version Far:     0x0000
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         AUTO
Trained Mode:            G.992.1 (ADSL) Annex A
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 ON                       ON
Line Attenuation:        19.0 dB                 14.0 dB
Signal Attenuation:      19.0 dB                  0.0 dB
Noise Margin:            30.7 dB                 28.0 dB
Attainable Rate:        10064 kbits/s            1156 kbits/s
Actual Power:            17.1 dBm                11.9 dBm
Total FECS:             0                        0
Total ES:               0                        0
Total SES:              0                        0
Total LOSS:             0                        0
Total UAS:              0                        0
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Bit swap:               0                        0
Full inits:             1
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Firmware        Source          File Name (version)
VDSL            embedded        VDSL_LINUX_DEV_01212008 (1)
Modem FW  Version:      110506_1916-4.02L.03.A2pv6C032b.d23i
Modem PHY Version:      A2pv6C032b.d23i
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0             2048             0               384
Previous Speed:           0                0             0                 0
Total Cells:              0          4602427             0                 0
User Cells:               0                0             0                 0
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Interleave (ms):       0.00             0.25          0.00              0.25
Actual INP:            0.00             0.00          0.00              0.00
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
