ā01-27-2013 07:50 PM - edited ā03-01-2019 07:14 AM
I am planning to redesign the DC by replacing the
existing 6500 catalyst cores with Nexus 7004
and introducing an access layer with multiple 6500 catalyst , nexus 5500 and nexus 2200 as access switches.
Are there any known issues for Nexus 7004 as core integration with 6500 catalyst as accesss ?
Any limitations to be considered while adding access-layer to Nexus 7004 ?
Diana
ā01-27-2013 11:33 PM
I don't think you'll have any problems, however a more detailed topology would help to be sure. Also, here's a whitepaper about N7k vPC integration with Cat6.5k VSS.
ā01-30-2013 03:31 AM
Hi DIana.
There shouln't be any incompatibility issues.
Just be sure that you have checked switch data-sheets to be aware abut capabilities of the devices:
http://www.cisco.com/en/US/products/ps9402/products_data_sheets_list.html
and plan your topology properly.
HTH,
Alex
ā01-30-2013 09:01 PM
Hi ,
Thanks for your reply.
Actullay I am planning to setup a pair of Nexus 7004 each with M2 series 24-port card. Connect them via VPC and configure them as L3 Core switches. Downstream to these cores , I have plans to connect 4 x 6500 catalyst as access switches and 2 pairs of Nexus 5548 with Fex associated on them.again as access switches.
I see no problems with Nexus 5500 integration with Nexus 7004, but not sure how well the 6500 catalyst can integrate with Nexus 7004.
Thanks in Advance
Diana
ā01-30-2013 11:05 PM
Hi Diana.
What do you mean under the term "integration".
If you are concerned about LACP, STP, VTP and routing protocols - there shouldn't be any issues.
VPC from the cat 6k side will be considered as standart port-channel - cat6k won't see that behind it there are 2 nexus.
Just be aware which topoligies are supported for VPC. For example you cannot run routing protocol over VPC links.
HTH,
Alex
ā03-22-2018 11:59 PM
Hello Diana,
Nexus 7004 integration with Cisco 6500 catalyst
There won't be an issues related to the topology mentioned below , it's a simple topology but just be careful about the configuration that you do on it , may be you can refer/crosscheck with a configuration guide for it .
