01-28-2013 01:27 PM - edited 03-07-2019 11:22 AM
I’m having an odd issue with a cisco 6513 not booting up enhanced flexwan card with clear channel/multi channel PAs. I’m not sure if this is happening with other types of cards but it happens with the enhanced flexwans that I have. For example removed a flexwan out of slot 8, which was working, and when I inserted it will not boot up. The 6500 resets the card over and over again and eventually turns power off to the card. It seems that most of the time when power is disabled %C6KPWR-SP-4-DISABLED to a line cards it’s because of (RESET) or (Module Failed SCP dnld) %ONLINE-SP-6-DNLDFAIL: Module 8, Proc. 1, Runtime image download failed because of scp send failure. At 1st I thought that make it’s the flexwans but from the error mesg I think it’s the PAs that are having the issues. Most of the time I now have to cold boot in order for the flexwans to work after I remove/insert them. Not sure if someone ran into this issue and can give me some hints or if this is a bug with the IOS im using, i dont have access to that. TIA, Paul System restarted at 01:58:34 est Fri Jan 25 2013 System image file is "disk0:s72033-advipservicesk9_wan-mz.122-33.SXI4a.bin" Last reload reason: Reload Command core.prv.ri#sh module Mod Ports Card Type Model Serial No. --- ----- -------------------------------------- ------------------ ----------- 1 48 SFM-capable 48-port 10/100 Mbps RJ45 WS-X6548-RJ-45 SAL0710A54G 2 48 SFM-capable 48-port 10/100 Mbps RJ45 WS-X6548-RJ-45 SAL09444KVM 4 0 2 port adapter Enhanced FlexWAN WS-X6582-2PA JAB084002AC 5 0 2 port adapter Enhanced FlexWAN WS-X6582-2PA JAB083402EG 7 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL SAD084202LK 8 0 2 port adapter Enhanced FlexWAN WS-X6582-2PA JAB093000QS 10 0 2 port adapter Enhanced FlexWAN WS-X6582-2PA JAB090400FF Mod MAC addresses Hw Fw Sw Status --- ---------------------------------- ------ ------------ ------------ ------- 1 0009.11f6.3590 to 0009.11f6.35bf 5.2 6.3(1) 12.2(33)SXI4 Ok 2 0015.f927.88b0 to 0015.f927.88df 7.1 6.3(1) 12.2(33)SXI4 Ok 4 0011.2133.5930 to 0011.2133.596f 1.6 12.2(33)SXI4 12.2(33)SXI4 Ok 5 0011.208b.d1b0 to 0011.208b.d1ef 1.3 12.2(33)SXI4 12.2(33)SXI4 Ok 7 0011.21ba.6d04 to 0011.21ba.6d07 4.0 8.1(3) 12.2(33)SXI4 Ok 8 0014.a8f6.b600 to 0014.a8f6.b63f 2.0 12.2(33)SXI4 12.2(33)SXI4 Ok 10 0014.6abd.0930 to 0014.6abd.096f 1.5 12.2(33)SXI4 12.2(33)SXI4 Ok Mod Sub-Module Model Serial Hw Status ---- --------------------------- ------------------ ----------- ------- ------- 7 Policy Feature Card 3 WS-F6K-PFC3BXL SAD084003XM 1.3 Ok 7 MSFC3 Daughterboard WS-SUP720 SAD083606NZ 2.1 Ok Mod Online Diag Status ---- ------------------- 1 Pass 2 Pass 4 Pass 5 Pass 7 Pass 8 Pass 10 Pass 2 port adapter Enhanced FlexWAN controller Board is analyzed ipc ready HW rev 2.0, board revision A0 Serial Number: JAB093000QS Part number: 73-9539-03 PA are rev 1.0 Below it shows what happens with a flexwan is not working and when it works. Slot 8 not working:
Slot 8 working:
1/25/2013 2:03:27 AM | Informational | 899: %OIR-SP-6-INSCARD: Card inserted in slot 8, interfaces are now online | ||
1/25/2013 2:03:21 AM | Informational | 898: %DIAG-SP-6-DIAG_OK: Module 8: Passed Online Diagnostics | ||
1/25/2013 2:03:21 AM | Informational | 897: %DIAG-SP-6-RUN_MINIMUM: Module 8: Running Minimal Diagnostics... | ||
1/25/2013 2:03:21 AM | Notice | 896: SLOT 8/0: * %FABRIC_INTF_ASIC-5-FABRICSYNC_DONE: Fabric sync on Primary channel done. | ||
1/25/2013 2:03:16 AM | Informational | 895: . %OIR-6-INSCARD: Card inserted in slot 8, interfaces administratively shut down | ||
1/25/2013 2:03:16 AM | Informational | 894: . %CWAN_RP-6-CARDRELOAD: Module reloaded on slot 8/0 | ||
1/25/2013 2:03:05 AM | Informational | 892: . %CWAN_RP-6-CARDRELOAD: Module reloaded on slot 8/1 | ||
1/25/2013 2:03:05 AM | Informational | 893: . %OIR-6-INSCARD: Card inserted in slot 8, interfaces administratively shut down | ||
1/25/2013 2:02:07 AM | Warning | 891: %C6KPWR-SP-4-DISABLED: power to module in slot 8 set off (Reset) |
Slot 13 not working:
1/25/2013 1:45:49 AM | Error | 906: %CWAN_RP-3-BOOTFAIL: The WAN module in slot 13/1 failed to boot | ||
1/25/2013 1:44:54 AM | Notice | 905: SLOT 13/0: %FABRIC_INTF_ASIC-5-FABRICSYNC_DONE: Fabric sync on Primary channel done. | ||
1/25/2013 1:44:22 AM | Informational | 903: %OIR-6-INSCARD: Card inserted in slot 13, interfaces administratively shut down | ||
1/25/2013 1:44:22 AM | Informational | 902: %CWAN_RP-6-CARDRELOAD: Module reloaded on slot 13/0 | ||
1/25/2013 1:44:12 AM | Debug | 899: sm(cygnus_oir_bay slot13), running yes, state wait_til_online | ||
1/25/2013 1:44:12 AM | Debug | 900: Last transition recorded: (power_on_ok)-> wait_til_online (powered_off)-> shutdown_pc (pc_powered_off)-> powered_off (operator_power_on)-> can_power_on (yes_power)-> powered_on (real_power_on)-> check_power_on (timer)-> check_power_on (power_on_ok)-> wait_til_online (reset_timer_online)-> wait_til_online (reset_timer_online)-> wait_til_online | ||
1/25/2013 1:44:11 AM | Informational | 898: %ONLINE-SP-6-DNLDFAIL: Module 13, Proc. 1, Runtime image download failed because of scp send failure | ||
1/25/2013 1:43:21 AM | Warning | 897: %C6KPWR-SP-4-DISABLED: power to module in slot 13 set off (Reset) |
04-23-2014 12:21 PM
turned out to be related to no enough ram on flexwan to support all 28 T1 using PPP/FR/MLPPP once the card booted up. this would also give us issue where the flexwan would work great from months then just stop passing traffic. upgraded ram from 256 to 512 and problem went away.
