UC560 with SPA525G2
riji
Hi All,
I've read from below UC500 Tele work best practice, and it said UC560 has some issue for phone VPN connection directly to it.
Has anyone tried setting up UC560 with SPA525G2 recently? I wanted to find out if this has been fixed. Or, is there any guidance for configuration if we do need to use an ASA.
https://supportforums.cisco.com/docs/DOC-22991
Rick
Hi Rick,
The issue has been resolved in the latest software pack 8.6.1.
Please take a look at the following link:
https://supportforums.cisco.com/docs/DOC-27771
2.  Key Bug Fixes:
CSCtw58664  - SSL VPN for SCCP causes crash  while clearing WebVpn session
CSCtt19900   - Packet decryption fails at crypto HW  engine for SSL VPN traffic with dtls
CSCtx59445   - MWI unsolicited mode fails with line  key monitoring a floating extension
CSCtr07804   - UC560 CUE  database corruption or crash due to high disk space usage
CSCtz08776   - CUE reports all channel resources used, not allowing calls
CSCts64962   - CUE IMAP - saved message count is negative. MWI always on
For  detailed list of fixes and known caveats see Release Notes.
HTH,
Alex
*Please rate helpful pots
