SNMPv3 support
Feb 1st, 2013
  • Cisco Employee,
                   Is SNMPv3 supported in the EEM SNMP ED???  I need to use SNMPGETs to retireve specific information
from a modem and it only supports SNMPv3????
Joe Clarke Mon, 02/04/2013 - 06:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, SNMPv3 is not supported for EEM operations.  Only v1 or v2c will work.
matthewathom Wed, 04/19/2017 - 09:37
Has there been any movement on this?  Or is v3 still not supported?
Joe Clarke Wed, 04/19/2017 - 10:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
As I recall, this thread was about doing polling from within an EEM policy.  No, this has not changed.  Only community-based SNMP is supported.  That said, we will be rolling out Python support for EEM in 16.5(1) for ISRs and Cat3850s, and it is possible to do more there with external scripts.  This still won't change the core EEM capabilities, though.
matthewathom Wed, 04/19/2017 - 13:37
Sorry...I should have specified.  I'm not so much interested in polling but the SNMP ED being able to read SNMPv3 authenticated & encrypted traps.  Based on your response though, I assume the same answer applies.
Joe Clarke Sat, 04/22/2017 - 11:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
That depends more on the SNMP manager built in to IOS than EEM.  I haven't tested this in a while.  Last I did, it did not work, but you might try it out with your code and see if that has changed.
matthewathom Sat, 04/22/2017 - 12:39
 I did try and I could not get it to work.  Even with v3 noauth I couldn't get it to work.  The receiving side debug simply stated that it was an invalid username despite the usernames matching.
Related Content
