Can RV042 limit the bandwidth for a certain website?
steeltoe159
Can it limit streaming websites? example "youtube" and torrent downloads? and dont affect other websites/ gaming speeds
currently has 50 units connected with 2 ADSL connections both with maximum down of upto 4.5mbps.
thank you
newbie here
ian
Te-Kai Liu
Level 7
Level 7
You could try configuring rate control rules (under System Management>Bandwidth Management) to "rate limit" the traffic (in terms of TCP/UDP port numbers) from specific IP address (or range). But this may not be sufficient for your need.
sir as of now i placed "HTTP [TCP 80/80] to min 512kbit per sec and max at 2000kbit per sec" will thathelp? wan1 and wan2 are checked.. and the 50 pc connected will that be enough for their browsing?
see attached picture.
