anyconnect xml profile
Answered Question
Feb 8th, 2013
I have anyconnect installed on my win7 PC but I am not able to locate xml profile file. Any clue where I should look for that?
I have already checked under Anyconnect installation folder and could not find it.
Correct Answer by Jouni Forss about 4 years 1 month ago
The folders in question are probably hidden by default on Windows. Change the Windows settings to also show the hidden folders
- Jouni
Overall Rating: 0 (1 ratings)
Jouni Forss Fri, 02/08/2013 - 05:02
Try these (depending on if you have the "old" or new AnyConnect Client)
C:\ProgramData\Cisco\Cisco AnyConnect VPN Client
C:\ProgramData\Cisco\Cisco AnyConnect Secure Mobility Client
C:\Users\username\AppData\Local\Cisco\Cisco AnyConnect VPN Client\
C:\Users\username\AppData\Local\Cisco\Cisco AnyConnect Secure Mobility Client\
username = your username naturally
- Jouni
Kashish_Patel Fri, 02/08/2013 - 05:05
Hi Jouni,
I dont see any AppData folder and also no Program Data (just program files)
Thanks.
Correct Answer
Jouni Forss Fri, 02/08/2013 - 05:09
- Jouni
Related Content
