Crypto Key Generate rsa command missing
Morning all,
I recently rebuilt the configuration of our Cat6500 multilayer device for use as a user stack. The device is funtioning as it should be, but I am unable to set SSH using the 'crypto key generate rsa' command. The crytop command isn't avaiable at all, which suggests a firmware issue.
I have configured a hostname and Ip domain-name and the image is the only one available.
The show version output is listed below.
show ver
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICES_WAN-VM), Version 12.2(18)SXF12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Sun 18-Nov-07 07:46 by kellythw
Image text-base: 0x01020150, data-base: 0x01021000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR:
Mercury uptime is 1 day, 23 hours, 11 minutes
Time since Mercury switched to active is 1 day, 23 hours, 11 minutes
System returned to ROM by reload at 17:00:43 UTC Wed Jan 28 2009 (SP by reload)
System image file is "sup-bootdisk:s72033-ipservices_wan-vz.122-18.SXF12.bin"
cisco WS-C6509-E (R7000) processor (revision 1.3) with 491520K/32768K bytes of memory.
Processor board ID SMG1110N3NP
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
4 Virtual Ethernet/IEEE 802.3 interfaces
100 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Patching is not available since the system is not running from an installed image. To install please use the "install file" command
Any assistance would be appreciated.
Jamie
Giuseppe Larosa
Hello Jamie,
it is a question of IOS image, you have:
a k9 code should be present in the the IOS image to support cryptographic features
To be noted it looks like this c6500 is running modular IOS that is not recommended on this platform and not developed /supported anymore. Several issues with modular IOS have been reported in the forums.
So the suggestion is to get a standard IOS image with cryptographic support.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Jamie,
Hope to help
Giuseppe
excellent, thank you for the answer.
Jamie
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
