Java - Unable to launch application
wgseligman
The problem: When I try to run ASDM on my Cisco 5550, I'm getting the dialog box "Unable to launch application". When I click on "Details", I see the error: "The application has requested a version of the JRE (1.5+) that is not installed".
The system I'm running this on is a Mac Pro with OS X Lion 10.7.5, and the latest Java version 7u13.
The initial lines of "show ver" on the firewall are:
# show ver
Cisco Adaptive Security Appliance Software Version 8.2(2)
Device Manager Version 6.3(3)
This is a relatively new problem; as recently as two weeks ago I was able to run ASDM with no problem. I suspect that the latest security-related Java updates have caused something to break.
Any ideas?
wgseligman
Solved this one on my own: The solution was to install the latest ASDM, 7.1.1_52. (This had occurred to me, but I didn't know if was compatible with the older ASA 8.2(2). It looks like it is!)
